Adding a 4 channel amp
Is it an easy install for a quality shop to add the amp? Seems I read conflicting info about connecting after market amps to a Bose speaker system. Will the power of the amp go through the HU then onto to the speakers? Will the shop need to do anything special to get the amp to work with the stock speakers?
Replacing amp without putting in new speakers isn't a good idea, the stock speakers can't handle any more power than they're already getting (and they're easily the weak link in the whole setup, but with the addition of the dash tweets it's not as bad as it used to be).
Amp power is a very well kept secret, but it isn't much. Speakers can handle a bit more, but changing only the amp isn't an option if you're looking for better sound.
Upgrading speakers will give minor improvement, but aftermarket amp and speaker upgrade is the only way to really get a jump in quality.
If you pull door subs you will lose some low bass, even compared to well powered components.
I do plan on changing out the speakers after the amp.At least it gets less expensive with each additional change. I do appreciate your input though.
It's also important to match specs of amp with the speakers you buy to get the best sounding system.
If your not going to do it at least have them run the rca cables and the amp trigger wire when the radio is out now. Then they will not have to take radio out later to upgrade to the new amps and speakers.
Like I said before, HU will be first, then the amp, followed by speakers. I want to hear the difference with each component installed otherwise I haven't a clue as to what helped the most.
If you already have it in your head to do it, why come here looking for advice?
I was told not to install an amp in my 2002 Ford truck for the same reason and 6 years later both the amp and stock speakers were fine.
Was hoping to get some actual first hand experiences with people who had actually did the amp install before swapping speakers. These are the type of opinions I value. People who actually tried it and could post factual results.
Whats the worse that could happen? Blow the speakers? Big deal, then I at least tried it and found the results. Would just mean I would be buying speakers sooner than later.
Now if any of you can tell me that adding the amp first would destroy something else in my system I am all ears.
OEM amp in a '13 Bose powers ALL speakers in the car, so you'll be losing the door subs unless you buy another amp for them. Door twiddlers are wired in parallel with dash tweets, personally I don't know what that resistance load is at the amps, possibly 2ohms or less, so not all aftermarket amps would even be able to do that without overheating.
You won't find many people who have done what you're asking about, if any, because it's just not something that would be considered a good idea.
From my personal experience, and many others, if you replace the entire door setup with components and add a 10" sub in the back with a single bridged 4-channel amp your sound will be TONS better than stock, regardless of the HU providing the music. An aftermarket amp(s) powering all stock speakers will most likely sound WORSE than the stock amp with it's included crossovers and processor. JMHO
It is pretty hard trying to figure out what to do. Some guys here claim the HU is the weakest link, others say the Bose amp sucks, and then others say the speakers are the weakest link.
The stock amp does what it was designed to do. However, compared to all but the cheapest aftermarket amps it would be considered weak. It also doubles as a crossover/processor for the signal coming out of the HU, which all but rules out a direct aftermarket replacement. The front twiddlers/tweets are 2 channels, center channel is another, door subs add 2 more, rears are a single channel mono output - all of that coming from one amp that's smaller than most decent crossovers.
Stock speakers are paper POS.
An aftermarket setup of 6.5" components in the doors, no rears, and a sub in trunk can be ran of of a 4-channel amp configured for 3-channel operation. I've put in several of them for other forum members in my garage, every one blew away the stock setup easily regardless of amp or speaker quality (assuming you don't buy the cheapest stuff wally world sells in the automotive isle).
If you have a HU with good output controls, a mid-grade amp, and the best speakers you can budget for.....
To answer your questions.... With the component/sub 4-channel setup the dash tweets are unused, door subs are removed, and rears are also unused unless you want to run them from the new HU internal amp for some rear fill.
Most good aftermarket 4-channel amps can be ran as 3-channel bridged for a sub. The front components have a crossover that takes the full speaker level signal from the amp and splits it to each speaker.
