I had some body work done on the Vette at a dealer's body shop. When I picked it up all the radio functions (display, tuning, volume indicator, etc.) work, but no sound. The dealer did let the battery go down and had to charge it with a big old commercial charger, but otherwise, the repair had nothing to do with the radio. The dealer is at a loss and so am I. What is going on here? Any ideas for a fix?
check the amp plugins make sure they are tight, check amp ground.
Sounds like amp is not turning on. Just a guess on my part.
If fuse is good, check trigger wire to make sure it's hot with the radio on. Circuit is at plug B3 of radio plug C1, but it can be tested in other places. C6 radio prints are HERE so you can find them.
