Sponsored by: Innova
sub woofer
Old Oct 31, 2013 | 05:05 PM
terry82's Avatar
terry82
Default sub woofer
I have a home subwoofer from the house that has a bad amp .the speaker is good .can I use the speaker add a 12 volt amp and put that in my car?
Old Oct 31, 2013 | 05:35 PM
Zorlac's Avatar
Zorlac
The ohm load may be different but I'll bet mobile subs are made for a more harsh environment unlike your home audio sub. But yes I bet it'll work.
Old Oct 31, 2013 | 06:11 PM
Homer3D's Avatar
Homer3D
Check the ohms. Most speakers designed for home use are 8 ohms and will not work properly when hooked up to a car’s radio or amp.
Old Oct 31, 2013 | 06:21 PM
terry82's Avatar
terry82
what ohm are kenwood car stereos ?
Old Oct 31, 2013 | 06:41 PM
Homer3D's Avatar
Homer3D
Car stereos are normally 4 ohms per channel with some aftermarket amps able to run 2 ohm per channel bridged.
Old Oct 31, 2013 | 07:09 PM
terry82's Avatar
terry82
I will take the sub apart and see what I have
Old Nov 1, 2013 | 05:19 PM
WAwatchnut's Avatar
WAwatchnut
It's not a matter of it not running properly - 8ohm speakers run fine on automotive amps. It's a matter of efficiency. Car amps are typically designed to run a 4ohm load. If you run an 8 ohm speaker, you effectively reduce the power output of the amp.
That being said, running a single 8ohm speaker on a 2channel car amp which is bridged into a single mono channel, is a perfectly acceptable configuration, and allows the amp to run "properly", with no loss in power from stereo 4 ohm configuration.
Most stereo car amps bridged will run a 4 ohm load, but few will run 2ohms.
To sub woofer
