Sponsored by: Innova
Compact Discs and Heat
Old Jul 8, 2002 | 02:04 PM
Bruce A De Boe's Avatar
Bruce A De Boe
Cruise-In III Veteran
Default Compact Discs and Heat
It got a little warmer today then what was expected today. I got into my truck and just began to wonder if it was to get hot enough in a closed black coupe if any damage could be done to compact discs in the changer or stored in any vehicle. Never seen any comments on this. Should the discs be removed if it gets too hot outside?
Bruce A. De Boe, D.C.
Old Jul 8, 2002 | 02:50 PM
ZippoMan's Avatar
ZippoMan
Default Re: Compact Discs and Heat (Bruce A De Boe)
Personally I dont think you will have any problems at all. From my experience CDs seem to be pretty bullet proof when it comes to heat. If it's 120 degrees outside and they're in direct sun light it could be a different story I guess. Are these CD-Rs or regular audio CDs? I would think CD-Rs would be more sensitive to heat.
Old Jul 9, 2002 | 06:06 PM
barkingowl's Avatar
barkingowl
Cruise-In IV Veteran
Cruise In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Default Re: Compact Discs and Heat (ZippoMan)
I don't think you'll have any problems. I have a 6 disc changer in the top of my van. The windows are always closed & it gets very hot in there. I've had the mirror fall off from the heat, but the CDs always play just fine. :yesnod:
Old Jul 9, 2002 | 06:49 PM
Bruce A De Boe
Default Re: Compact Discs and Heat (barkingowl)
Thanks guys. Wasn't one of those major problems, just a thought passing through when I got into my truck the other day and it was quite hot in there.
B. De Boe, D.C.
Old Jul 16, 2002 | 05:02 PM
fdxpilot's Avatar
fdxpilot
CPU Magazine just did a torture test on various CD-Rs and CD-RWs in their August issue. One of the tests was to leave the 6 disc brands they were testing in jewel cases on the dash of a car in Arizona all day at 103 deg. They said all the jewel cases warped but the CDs didn't, and most worked fine, although they had trouble getting data off a Memorex CD-R afterwords. Just thought you'ld like to know :D
To Compact Discs and Heat
