Sponsored by: Innova
PAC OEM 1 wiring
Old Jan 28, 2014 | 04:35 PM
Pirateslife4me's Avatar
Pirateslife4me
Default PAC OEM 1 wiring
I'm totally over thinking I'm sure... I know the factory radio wire harness doesn't have an ignition wire and I need to tap off the the one in the footwell but do i just cut off the red wire coming out of the PAC OEM 1 harness or should I connect that to the red ignition wire of the aftermarket HU that I will be running to the footwell? Basically does the PAC OEM 1 need an ignition input to work or can I just forget about/remove the red on the PAC harness?
Old Jan 28, 2014 | 06:54 PM
markcz's Avatar
markcz
What year is your car?
Are you replacing radio or speakers/amp, or both?
Old Jan 28, 2014 | 07:17 PM
Double D Mods's Avatar
0Double D Mods
Former Vendor
St. Jude Donor '12-'13
red from radio direct to yellow in footwell
for all 97-03
yellow under steering column for 04
no connection for the red on roemvet1
Old Jan 28, 2014 | 10:51 PM
Pirateslife4me
Its a 1998, replacing HU. Thanks DD that is exactly what I was wondering.
To PAC OEM 1 wiring
