Sponsored by: Innova
Backup camera quality differences?
Old Feb 15, 2014 | 12:41 PM
LD85's Avatar
LD85
Default Backup camera quality differences?
Is there any kind of difference in the quality of the backup cameras?
The prices seem to swing from low to high but they appear to have similar resolutions.
Old Feb 15, 2014 | 04:21 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
In my opinion the higher end ones do produce a better picture. I have installed everything from 200 dollar kenwoods to 20 dollar eBay specials from china. It really depends on what you wanna spend. My own car a 20 dollar china special is good enough for my needs
Old Feb 15, 2014 | 06:55 PM
LD85's Avatar
LD85
Thanks, I thought they were a waste until I had to backup several times around people and I sort of think it is useful now. The $60 license plate bracket Boyo camera seems sufficicent
I hoe you are staying warm in W.L.
Old May 17, 2014 | 05:58 PM
LD85's Avatar
LD85
I bought a backup camera, do I have to take the head unit out of the dash to plug in the cable?
Old May 17, 2014 | 10:47 PM
markcz's Avatar
markcz
Unless you thought ahead and ran power and a video connection out to where you could get at it when you installed the radio, yes.
Old May 18, 2014 | 06:50 AM
LD85's Avatar
LD85
Thanks, I figured it but though I would check, I plan to get power and signal at the backup light so I guess I will run a short cable from the head unit to an access area, and then plug into that spot in case the camera dumps and I need to replace it, thanks!
Old May 18, 2014 | 11:41 AM
Double D Mods's Avatar
0Double D Mods
Former Vendor
St. Jude Donor '12-'13
I would buy anything but Boyo myself...We have all kinds of problems with Boyo....
The Pyle one we offer is the best. Had parking grid lines as well.
I have 2 PLCMIR38 and a Crime Stoppers switching unit as a package to run front and rear cameras for 99.99
Old May 18, 2014 | 02:59 PM
markcz's Avatar
markcz
When installing the radio you also need to connect the purple wire to the reverse light signal so it will automatically switch to the camera, don't forget about that one also.
Old May 18, 2014 | 03:00 PM
markcz's Avatar
markcz
Good to know
Old May 18, 2014 | 03:23 PM
reath1's Avatar
reath1
That Pyle deal would be what you're sending me right Dennis?
Old Apr 2, 2015 | 10:27 AM
KevinD92's Avatar
KevinD92
Is this deal still available?
Old Apr 2, 2015 | 10:32 AM
0Double D Mods
Former Vendor
yes
but pending what radio you have you might not need the switching unit
just call me
Old Apr 2, 2015 | 11:10 AM
KevinD92's Avatar
KevinD92
yes
just call me
I'm unable to call right now. I have a Pioneer AVIC Z110BT.
Old Apr 2, 2015 | 09:06 PM
Mike Beck's Avatar
Mike Beck
Got mine through Amazon, not sure what brand, yes, something cheap from China. It is the entire license plate frame. Hooked it up to my Pioneer double din, works great, except....... When it is humid or cold outside, the nice warm exhaust fumes tend to fog-up the camera for awhile. It does have the parking grid lines, works pretty good. I think it was certainly worth buying, unless I have the top down, then I can see the world and the camera is not needed at-all.
Old Apr 4, 2015 | 11:48 PM
Saving41's Avatar
Saving41
Dennis,
Will your kit work with the factory head unit on a 2015 C7? Can the PLCMIR replace the poor quality factory rear camera?
Thank you for any information!
Old Apr 6, 2015 | 03:27 PM
LOUSVETTE's Avatar
LOUSVETTE
NCM Member
Can you give me a heads up as how the use the backup light for power to the camera? Would be very helpful
Old Apr 6, 2015 | 06:20 PM
markcz's Avatar
markcz
Connect red power wire from camera to green wire (+12v) going to backup bulbs (same wire as purple trigger wire connects to). Black camera wire gets grounded.
This would only power up the camera when you're in reverse. If your radio supports looking at the camera while going forward, you won't be able to do that.
To Backup camera quality differences?
