Sponsored by: Innova
Profile Amps!?!
Old Jul 14, 2002 | 02:52 PM
Sexy99C5's Avatar
Sexy99C5
Default Profile Amps!?!
I'm looking to get a single channel amp to power my 10" Alpine Type R. I'm looking for something around the 300x1 range. I came across the Profile CL600M. I don't really know much about this brand, but compared to the prices of its major competitors (alpine, kicker, RF) it seems to be definitley the most bang for my buck. Has anyone had good or bad experiences with these amps? I'm strongly thinking about buying one, but if it isn't what its made out to be i'd rather pay a little extra and get something better. Any help would be greatly apprieciated. Thanks...
Old Jul 14, 2002 | 03:58 PM
M396 #00-011's Avatar
M396 #00-011
Default Re: Profile Amps!?! (Sexy99C5)
I would consider looking around some more. Havern't heard much good press on Profile. They maybe a few steps up from Jensen. Remember, MOSTLY, you get what you pay for.
Possabilities for Large name entry lines would be RF, Kicker, Coustic, etc.
Old Jul 14, 2002 | 04:16 PM
Sexy99C5's Avatar
Sexy99C5
Default Re: Profile Amps!?! (M396 #00-011)
I didn't realize they were about as low as jensen, looks like i'll stick to my original kicker plan. Have you heard much about a KX300.2?
Old Jul 14, 2002 | 04:57 PM
M396 #00-011
Yes, not a bad amp. Normal 4 ohm mono output is around 400-430 watts. Is your Type R single 4 ohm coil?, sorry, not too familiar w/ the subs.
Old Jul 14, 2002 | 05:35 PM
Sexy99C5's Avatar
Sexy99C5
On the alpine type r's you can either get 2 ohms per voice coil or 4 ohms per voice coil, and its dual voice coils. I have the dual 4 ohm voice coils.
Old Jul 14, 2002 | 05:36 PM
Sexy99C5's Avatar
Sexy99C5
^^^ I think thats right, some audio guru tell me if it is...
Old Jul 14, 2002 | 07:43 PM
JoeyG's Avatar
JoeyG
Cruise-In III Veteran
Cruise-In IV Veteran
Should say on the box, or will be printed on the magnet somewhere. Jason knows his Kicker equip. though. :yesnod:
Old Jul 14, 2002 | 08:03 PM
M396 #00-011
If they are dual 4 ohm coils, the 2 ch Kicker amps will not work. You will have to look at the KX400.1 or another brand.
Old Jul 14, 2002 | 08:26 PM
Sexy99C5's Avatar
Sexy99C5
I think they maybe be 2 ohms per coil.....in which case it would work, right?
Old Jul 14, 2002 | 08:32 PM
M396 #00-011
If it is in deed 2 (2 ohm) coils, then you could series wire the voice coils, effectively creating a 4 ohm load on the amp. This would work for the 300.2. If they are 2 (4 ohm) coils, parallel them and use the 400.1.
Old Jul 14, 2002 | 10:21 PM
Sexy99C5's Avatar
Sexy99C5
Ok, I just found out for sure, it is dual 4 ohm voice coils. So as far as amplifiers, any suggestions?
Old Jul 14, 2002 | 10:33 PM
Sexy99C5's Avatar
Sexy99C5
Basically what I need is either a mono amp that handles 4 ohms, or a 2-channel amp that can be bridged to handle 4 ohms, correct? I found a Rockford Fosgate Punch 300-400S, those seem to be good candidates if they will work, will they??
Old Jul 17, 2002 | 01:49 PM
M396 #00-011
Sorry, this is wrong. What you need is a mono or 2 ch amp that can handle a 1 ohm stereo or two mono load (same difference) In the Kicker amp line, this would be the 400.1 or 600.1 single ch mono D class amps. the 400.1 would be plenty of power (almost 500 watts) had for about $350.
Jason
To Profile Amps!?!
