Sponsored by: DashLynx
Some albums on USB key in random order
Old 04-06-2014, 09:39 PM
Jim Rogers
Jim Rogers's Avatar
Default Some albums on USB key in random order
Hi--
Searched the forum and the manuals and can't find an answer.
Have a '13 c6 GS, with stock nav unit. I have an 8 gb usb key that has about 20 albums on it. For about 1/3 of those albums, the song list comes up in a random order, for the other 2/3 of the albums the song order is correct.
The ones that come up in the wrong order are always in the same (wrong) order. If I open that USB key on the computer, all the song's track number tags are correct, and in the 'vette it does show the correct track number.
However, the songs (correctly labeled for track) will not be in the correct track order.
If I use that exact USB on any other player (stereo, computer) all 20 albums have all tracks in the correct order.
Any information for me on this?
Thanks!
Old 04-07-2014, 06:39 PM
markcz
markcz's Avatar
Plug the drive into a computer, open one of the folders so you can look at the MP3 files, right click on one and select properties.
Compare the info for an album that appears in the proper order with one that doesn't, if you're lucky it will be obvious (like the # not being there, or not all MP3's being assigned to the same album).
Old 04-07-2014, 08:54 PM
tbrowne
tbrowne's Avatar
You need a program to sort the files on your drive. Some units play the music in the order that it was written to the device, called arrival sequence, and others sort the music alphabetically or numerically the way you probably see the file on a computer. I use a program called DriveSort that can sort the files on the USB in a number of different ways. Find the program at the link below - it's free but the author does ask for a donation if you like the program.
http://www.anerty.net/software/file/DriveSort/
To Some albums on USB key in random order
Quick Reply: Some albums on USB key in random order
