Sponsored by: Innova
Big 3 question:
Old Apr 10, 2014 | 03:30 PM
alxltd1's Avatar
alxltd1
St. Jude Donor '10-'12-'13-'14-'15-'16-'17
Default Big 3 question:
Getting ready to move the battery to the rear of the coupe and install the Big 3 upgrade also (though now it is way beyond 3). Upgrading audio system, as well as adding a number of new relays (hence the addition of a new aux post under the hood) to handle the fail safe system for the nitrous system. Diagram (please pardon the simple illustration as I am no electrical engineer) shows the wiring I am going to install. Any expert comments are welcome regarding the wiring routes. Thanks.
Old Apr 11, 2014 | 08:42 PM
markcz's Avatar
markcz
Looks good.
I don't see why you couldn't go to the fuse box post from the battery instead of to the starter motor, may be easier to run the cable.
Do you have a plan for a fuse of some type near the relocated battery?
Old Apr 11, 2014 | 09:21 PM
alxltd1's Avatar
alxltd1
Originally Posted by markcz
Looks good.
Thanks. Yes the kit (from SAC city) has a 100amp fuse included by the battery connection. I am using their kit but obviously extending the wire runs. The rationale for running from the battery direct to the starter was a suggested route from another forum member. I assumed it just ensured a direct run without a junction point in between.
To Big 3 question:
