Need an amplifier recommendation.
morel is one of the best names in hi-fi, they are often compared with dynaudio and focal. they also have one of the best cone midranges ever in their higher end auto suprimo components which are $5 grand a set. some of their home speakers, like the fat lady are works of art. google morel fat lady if you want to see something cool. they are all carbon fiber enclosures that are tuned to play along with the drivers
the kicker 08KS6502 can be had for 157 online and is one of the direct competitors to the c2 but i have no idea if they are better, louder, or much of anything, have never heard the two side by side. i would assume the kickers are louder just based on the KS line in general. the focal 165as is a competitor to the morel tempo but you also jump up to that 250 mark in most places online.
all comes down to what you can spend. just to juggle money i think you would be happier ditching the 10w3v3 which you're probably paying 200 for in place for a $65 RE audio rex10v2 the re audio rex specs pretty decent, it just won't take as much power as a w3 and that's okay if you're just using the bridged 2 channels off a 4ch amp. put that extra money into a good component set like the morel tempos, or the focals, or even JL c3's. it's very very easy to get bass response in a corvette. a good front stage is what will really bring your music to life.
think about it this way. the human ear can hear 20hz to 19-20khz
the average sub plays 30-35hz to 80hz in the average car. that's barely over 1 octave. really good subs like the w6, w7, peerless xxls or others can go to 20 no problem but that's more money
your components play 80 to 20khz which is virtually the entire audio spectrum our ears can hear short of the lower 2 octaves which are 80 to 40 and 40 to 20
If $600 is your limit, the items Dennis mentioned would sound pretty good at that price level:
Give us a list of any parts you may have already purchased, along with a MAXIMUM additional cost for all remaining parts, then we can talk specifics
I still need a box. Like vettenutz in the cubby, this will be another $225 if they run the holiday deal again on Labor day like they did on the 4th. I don't see any CVT c6 boxes on Dennis's site.
I'll spend more on components up to $300 if it's really worth it for more volume over the C2's if they're worth double the price. C2's I can get for $150. If i'm already spending the money, $100-$150 more just for a little bit more volume over stock isn't worth it, it'd have to be noticeably more.
Then, there's the mids. Do I want them or ditch them? If I get an amp to go in stock location, then i'd need an amp to power another set of components for the rear. Would it be louder with better rears or ditch them and spend more for better fronts?
Still need amp which I stated earlier in the $200 ballpark like the PN5 or Power Acoustic.
Not trying to win any comps of course. Previous c5 had 1 jl 10w3v2 powered by Rockford Punch 500. Stock fronts and rears off Bose. Bass was good, but highs were terrible.
This setup is already looking like it'll be over my original budget of $700.
the c2's could work for you, IF you also use the c2 coaxes in the rear. beings you can't fade with a single 4ch amp when you have a sub running off the rear two you can create your own fader with resistors. earlier i mentioned using morels for my rear 5.25s, they are louder than the c2's but i addressed this by using 6ohms of resistance on the + side of each one. you can get 8 20watt 20ohm resistors on ebay for $4.80 shipped. use 4 on each side to create a 80watt resistor that's 5-6ohms. this will bring those speakers down somewhere around 6db and properly set your front stage.
if possible go listen to the morel tempo 6, jl audio c3 6.5's and focal 165a1 or p165v15. in fact woofersetc actually has the focal 165a1 components on clearance for 229 shipped and these were a 350 set of components before the p165v15 replaced them
jl audio has one but it's not cheap, the xd700/5 which is around 500 dollars. i know that double d guy sells a lot of the kenwood 5ch amps and at your price point it may be a best buy. may also ask about a combo with the amp and the c2 setup you're thinking of, see if he will price match to sell it all. fosgate also has a few micro digital amps in their lineup
power comes down to how much you want to spend
yet another option if you're a jl audio fan is to use the c3 components up front only which cost similar to the c2 front and rear combo. you then could use a less expensive amp like the xd500/3 which can be had new online around 279 dollars. this is a neat little amp that's very small and pumps out 2x75w and 200x1 which would work well with c3 components and you're existing sub
system would also be 100% JL which could be a perk for resale
Re the volume.... Compared to stock, even without amped rears, ANY component set with 50wRMS or more will absolutely blow stock away. Find an amp/speaker combo that can cleanly put out 100w and your ears may start to bleed if you crank it with the windows up. "Compared to stock" isn't an issue. What he's saying is the C2 aren't quite as loud as other brands at a comparable power level.
The 10w3v3-4 is recommended 100-500wRMS. If you're already leaning towards the BAMF1600/4, it will put out 360wRMS to the sub (just about perfect for that sub IMO) and 150w to each component set. I would be looking for a component set that is rated for more than 60wRMS. The Polk MM6501 cost about the same, sound pretty darn good, and are rated at 125w.
Just a few things to think about
but
amplifiers are still a concern if he wants to run 2 sets of highs with 5.25s in the rear and 6.5s up front. to have the capability to fade he'll either need a 5ch amp, OR, the knowledge on how to design L pads for the rears.
using a 3/4 ch amp would be great if he just used front components but tying the fronts and rears together on 2 channels means no fading unless you use L pads. you can fade highs to sub well enough on the electronic controls but that's it
If I have a 4ohm w3, did I get the wrong impedance to get 2ohm power? I still don't understand the impedance thing.
Will the c2 combo work at 2ohm, with the sub being 4 is basically what i'm asking or do all speakers have to run one or the other?
if you run just the c2 components in the doors you will be at 4ohms on the highs. if you run the components AND the coaxes on 2 channels of a 4 channel amp you will be at 2ohms and if they are ran on separate channels of a 5ch amp you will be at 4ohms. see how that works? seperately they are 4ohms but tied together you can make it 2ohms
as for the sub, if you have an older DVC w3 that's 4ohms you can wire the coils in parallel to get 2ohm. if it's a single voice coil w3 like the w3v3 they are simply 4ohm
your amplifier can run any mix of 4 and 2 ohms. the front 2 channels for the highs could be at 2ohms and the sub at 4, the amp does not car, power output on unregulated power supply amps goes up the lower the ohms go, but so does heat and current. regulated amps play virtually the same at 1-2-3-4-5 ohms.
remember you can always use your digital multimeter to check ohms at the wires before you secure them to the amp
or you could get an amp like the jl audio 250/1 or phoenix gold xenon 400.1 for a sub amp. they often sell for 100 used. they put out the same power at 4 or 2 ohms
