Sponsored by: Innova
94 Radio Replacement
Old Jul 24, 2002 | 10:25 PM
rxalot's Avatar
rxalot
Default 94 Radio Replacement
I am deathly afraid of yanking plastic trim pieces, fear of something breaking. I would appreciate info on how to remove the front plastic trim with no to minimal damage, specifically where the attachment points are and if there are any screws.
I have joined the Bose haters club (previously a Bose home hater, now a car hater).
Thanks ahead.
Old Jul 25, 2002 | 12:00 PM
92TripleBlack's Avatar
92TripleBlack
Default Re: 94 Radio Replacement (rxalot)
Yours is slightly different from mine but I believe has the same screw points.
2 screws under felt/carpet liner in center console. Peel the corner's up to expose screws.
1 screw under ashtray
Lift the piece around the shifter exposing two screws on the bottom of the dash piece. Remove those screws.
Remove vent above radio-2 screws
Remove screw behind vent.
This should free the dash piece except for a clip or two and it should just pop out.
Last, don't be to afraid. Replacement for this piece is still available from GM. The one for my car is $35 so it can't be that much. I keep all the screws in the ashtray cup so I don't loose any.
Good luck. :smash:
Old Jul 25, 2002 | 07:21 PM
rxalot's Avatar
rxalot
Default Re: 94 Radio Replacement (92TripleBlack)
Thanks for the info. You were correct that there was a difference.
2 screws removes the top vent
4 screws remove the center console compartment door
3 screws remove the center console (including the one under the ashtray)
3 screws remove face plate (there is also one push connector mid way on the left)
Of course, now I am really beginning to hate Bose. The Scosche adaptor connects to the remote module in the storage compartment. So now I have to run some wires from the front to the storage compartment, including an extended antenna wire.
It's never Cheap, Easy, or Quick.
92TB, again thanks for the response.
To 94 Radio Replacement
