Sponsored by: Innova
BOSE amp bypass for 2007 z06
Old Jul 12, 2014 | 11:29 AM
gt40mki's Avatar
gt40mki
Default BOSE amp bypass for 2007 z06
I've read everything I can find in the FAQ and beyond - but am looking for an easy way to remove the factory BOSE amp and possibly the os2cbose now that i've eliminated onstar (module, antenna, etc), and don't care for the chime anyway.
Is there a bypass plug available for the amp? Perhaps a way to jump the plug like I did for the onstar module? Looking to do as little damage to the OEM harnesses as possible.
Is there anything the os2c does if I'm not using onstar/and don't need the low level in to the OEM amp?
Thanks in advance!
Old Jul 12, 2014 | 05:34 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
It gives you rap power. Unless you have an aftermarket amp to drive speakers I do not recommend bypassing oem amp
Old Jul 12, 2014 | 10:00 PM
markcz's Avatar
markcz
If you use switched power from fuse box and don't mind losing the chimes you can eliminate the os2c completely, but you'd need to have an aftermarket amp and speakers/sub to make it sound good.
If you're keeping the oem speakers, just use oem amp
Old Jul 13, 2014 | 12:46 PM
gt40mki's Avatar
gt40mki
Thanks for responses - I failed to mention I have polk components with crossovers up front (coax in back) I'd like to drive off the pioneer and a 10" sub/amp in the back...
Pardon my ignorance - what is RAP power?
Old Jul 13, 2014 | 07:33 PM
markcz's Avatar
markcz
Retained Accessory Power is what keeps the radio on until you open a door. Pure switched power would be on with acc/ignition and off when your turned off motor.
I haven't seen a radio yet with an internal amp powerful enough to make 6.5" components sound like they should, you really need an aftermarket amp for them. Have you bought the sub amp yet?
Old Jul 18, 2014 | 01:19 PM
gt40mki's Avatar
gt40mki
Ok - if I keep the bose amp is it cool to drive both the 6.5 and the tweeter off the twiddler signal coming from the amp? (plugs on the door panels)
Old Jul 18, 2014 | 08:40 PM
markcz's Avatar
markcz
NO
You would probably barely be able to hear the components if you hooked them up to the stock twiddler wires coming from the stock amp.
What is currently installed in the car (list ALL speakers, amps, etc...)
To BOSE amp bypass for 2007 z06
