Sponsored by: Innova
C5 Antenna Adapter needed (straight)
Old Jul 13, 2014 | 03:08 PM
IRON MAIDEN's Avatar
IRON MAIDEN
Default C5 Antenna Adapter needed (straight)
Looking for an antenna adapter to connect to an aftermarket radio. The ones I'm seeing all have a right angle on the end that plugs into the back of the radio. My head unit has a pig tail antenna plug so I don't want the adapter exiting it at a right angle.
What adapters do not have this???
Old Jul 13, 2014 | 07:26 PM
markcz's Avatar
markcz
Those adapters are designed to fit behind the radio, so a straight one wouldn't work too well in most cases. I don't recall ever seeing a straight one
Old Jul 13, 2014 | 11:23 PM
IRON MAIDEN
Check my thread later. I will be agreeing with you! Spent all day cutting out the upper brace. For a single din unit! Then it still wouldn't fit. There was a little plastic hook off the ac unit that was in the same location as one of the harnesses on the head unit. Go figure I pick a head unit that is deep as **** and has all the rca's off the upper right of the backside. So removed the hook. Still barely fits! It's tight enough that it forces the back of the unit downward causing the front to angle up. So I had to make another brace to support the back of the unit. It's tight back there but will work. I'll replace this one after a while and make sure I find one that isn't as deep or t least has it's hookups off the bottom side of the backend.
Old Jul 14, 2014 | 08:25 AM
Double D Mods's Avatar
0Double D Mods
Former Vendor
St. Jude Donor '12-'13
you need 90 degree rca adapters for the back for the radio to give you the depth
Old Jul 14, 2014 | 12:13 PM
IRON MAIDEN
All the RCA and other inputs/outputs on the back of this JVC use the pigtails so they are not needed. Problem is that they exit the back of the HU on the upper edge. As you know, the back wall is angled and those pigtails coming out of the HU rest right up against it. Not much I can do other than space out the HU in the mount which would leave the faceplate sticking farther out. Would look horrible. I'll leave as is. Should be fine. If it causes problems with the outputs, I will replace the unit.
To C5 Antenna Adapter needed (straight)
