Sponsored by: Innova
Sealing a sub..
Old Jul 27, 2002 | 08:41 PM
Kale's Avatar
Kale
Default Sealing a sub..
Major pain in the butt, or easy?
I've only had 1 sub i could get to seal the first time around,
now im just not worrying about the "miniscule air leaks"
how bout you?
Old Jul 27, 2002 | 11:31 PM
_Nomad_'s Avatar
_Nomad_
From: Frankenstein never scared me. Marsupials do, because they're fassst…and they DART, THAT'S crazy!
Default Re: Sealing a sub.. (Kale)
Just keep the box caulked well and you should be fine. :D
Old Jul 29, 2002 | 12:04 PM
mrkln's Avatar
mrkln
Default Re: Sealing a sub.. (The^Nomad)
Just caulk or silicone it. Its a breeze. :yesnod:
Old Jul 31, 2002 | 11:53 PM
AP's Avatar
AP
Default Re: Sealing a sub.. (mrkln)
Silicone it ... if you havent made the box yet ... pre drill the holes ... put silicone on the joint then screw the box together ... thats how I did my dad's box ... and then added silicone to the joints again ... wel worth the $5 for the 2 tubes ...
Old Aug 13, 2002 | 12:17 PM
Audiowizard's Avatar
Audiowizard
Very easy! If you have a good table saw and make all of your cuts straight, you wont really need to use silicone. I pre-drill and countersink first and then use wood screws (sheet rock screws) with wood glue. The wood glue acts as a sealant once you bring pressure to the joints with the screws and then wipe the excess with your finger and force it back into the joints. It doesnt hurt to use silicone afterwards if you want to be on the safe side but is really not necessary.
Old Aug 20, 2002 | 04:51 AM
hrdtopv8's Avatar
hrdtopv8
Default Re: Sealing a sub.. (Audiowizard)
I do all the above and a little extra. I pour some fiberglass resin inside the box (through the speaker hole) and swirl it around. You have to do this fast or the resin will harden to where you won't be able to seal it. After it hardens the resin will seal all the porous holes in the box and joints. You will get a much tighter bass effect. It sounds AWESOME!! :D :seeya
Old Aug 23, 2002 | 08:38 PM
C5Noir's Avatar
C5Noir
Default Re: Sealing a sub.. (hrdtopv8)
Liquid nails is the best, by far.
Old Aug 24, 2002 | 06:52 AM
KouKou's Avatar
KouKou
I personally enjoy fiberglasing my boxes, but silicone works well 2 :D
Old Aug 29, 2002 | 05:16 PM
MY2K2C5's Avatar
MY2K2C5
When I finally decided on the configuration I was going to use I went through 5 tubes of liquid nails. It is sealed like a drum if you know what I mean.
Old Sep 2, 2002 | 01:09 AM
Conquer's Avatar
Conquer
St. Jude Contributor
Default Re: Sealing a sub.. (AP)
MY FAVORITE RECIPE + MORE SILICONE :p: AND PLENTY OF SCREWS FOR A MORE SOLID BOX
To Sealing a sub..
