Sponsored by: Innova
c4s
Old Jul 28, 2002 | 07:41 PM
1996man's Avatar
1996man
Default c4s
anyone have any pictures of their sounds systems in C4s that include some sort of subwoofers? i am looking into some different options as to how to place 1 or 2 subs in a late model C4 losing as little storage space as possible
Old Jul 28, 2002 | 08:55 PM
DF's Avatar
DF
Default Re: c4s (1996man)
A few people have subs installed where the rear speakers go. Is this something that you would consider?
Old Jul 28, 2002 | 09:15 PM
_Nomad_'s Avatar
_Nomad_
From: Frankenstein never scared me. Marsupials do, because they're fassst…and they DART, THAT'S crazy!
What about this?
http://forums.corvetteforum.com/zerothread?id=349415
Old Jul 29, 2002 | 12:05 PM
1996man's Avatar
1996man
Default Re: c4s (DF)
DF, is that possible? are they like free air subs? what size? 8s? i didnt think you had enough air behind there to make that work. i have never seen a setup like that much less knew anybody was doing that. that would be perfect. do you have any pics of that?
Old Jul 29, 2002 | 12:44 PM
DF's Avatar
DF
I haven't looked into it much, I have just read that people have done it :)
It is talked about some in this thread. One guy there has done it. http://forums.corvetteforum.com/zerothread?id=330508
Old Jul 29, 2002 | 10:36 PM
_Nomad_'s Avatar
_Nomad_
I have seen and heard such an install and it is absolutely horrible. First of all an 8” really isn’t big enough to give any decent bass response in that hatchback and any woofer that would fit in that spot (after modification to get it installed) would not have enough airspace to operate in. Proper enclosures are very important to woofer performance. Using it as a midbass wouldn’t work either because you need all midbass up front to draw your sub frequencies forward.
However, if you don’t mind anemic bass then it might be an option for you. :)
Good luck. :seeya
Old Jul 29, 2002 | 11:46 PM
Ericthewolf's Avatar
Ericthewolf
Default Re: c4s (The^Nomad)
LOOK INTO KICKER SQUARE SOLOBARIC SUBS.. EXTRA SMALL ENCLOSURES TONS OF BASS IF YOU POWER THEM RIGHT..EVEN THE 8INCHERS..I RECCOMEND PRECISION POWER AMPS.
To c4s
