Sponsored by: Innova
JL Audio Sub, Install instructions???
Old Jul 30, 2002 | 10:56 PM
BlackSun!'s Avatar
BlackSun!
Default JL Audio Sub, Install instructions???
Can someone post the install procedures to install this???
Is it hard or should I just take it in and spend the $200 to install it? :confused:
Old Jul 30, 2002 | 11:34 PM
bogus's Avatar
bogus
Default Re: JL Audio Sub, Install instructions??? (BlackSun!)
are you using a stealth box?
Amp?
talk to me...
Old Jul 31, 2002 | 12:25 PM
BlackSun!'s Avatar
BlackSun!
Default Re: JL Audio Sub, Install instructions??? (bogus)
Yep, The stealth box with a precision power amp. I had gotten the whole package from Chris, including the wiring harness to run from the head unit back.
Old Jul 31, 2002 | 11:44 PM
bogus's Avatar
bogus
so this is a tag along with the OEM system....
you should be able to handle it... it will take time. you will have to run power to the battery, and find ground to either the chassis in the rear or the battery to the front. the audio hook up should be straight forward. I donno what you have, but there should be instructions with the harness.
$200.00 to install that is a bit steep...
Old Aug 3, 2002 | 01:25 AM
DPC5's Avatar
DPC5
Actually 200.00 for and AMP and SuB is not bad...Make sure they they do a "clean" install in the amp...no wires showing.
To JL Audio Sub, Install instructions???
