Need install advice.
I want to mount the amp against the back wall under the hatch. How should I mount this? Directly throught the carpet to the back panel or some other way and with what hardware?
[Modified by Charlutz, 4:10 AM 8/4/2002]
1. Do I need to insulate the enclsures?
2. Is the carpet easy to pull up and replace, because I will be putting down sound deadening material and new wires?
3. I don't have room under my seats, so how should I mount the amp to the rear?
For the coup you simply remove the entire Blose pod, which easily comes out after removing only a few screws around the edges under the carpet. It will have a ready made space to just drop a 6x9 speaker in and screw it down, no problem. You can even replace the stock speaker grill cover over it and no one will even know you have anything other than a stock setup.
Since the ’95 front speakers are on the frame rail then you will need to build out the top of the speaker cover after installing it as to have enough clearance for the grill from the speaker. 92TrippleBlack, from what I have read, has done this with his Vette and I’m sure he will be glad to tell you how he did it. I believe he build an entire new enclosure though.
As for the amp, if you wish to mount it on the rear wall of the hatch under the glass then you will need to build wall from MDF for the amp to secure to. Remove the carpet from the back by taking off the plastic hatch deck trim, unscrewing the carpet tabs and unhooking the rear carpet from the mounting screws. Pull the carpet back and you will see there is only some insulated carpet padding under it. Cut a piece of ¼” to ½” MDF to fit in that area and act as a foundation to mount the amp to. Since ¼" MDF is hard to find you may have to use ½”. Once the MDF is secured in place, replace the padding and carpet and screw your amp to the MDF over the carpet. Don’t forget to run your wires before replacing the interior carpet and trim. :D
Also, amps are best mounted horizontally (flat on the floor) however, when mounting an amp vertically like you will be, make sure the heat sink cooling fins are facing vertically (straight up and down) and not horizontally. It will help cool the amp better that way. :yesnod:
Hope this helps. :seeya
How would you suggest I mount the MDF for the amp? Just cut it to fit tight, velcro to the rear panel, glue, etc.?
Good luck. :seeya
