*NEW PRODUCT* VetteNuts C7 Corvette Corner Sub Boxes
These are built in house by American workers!
These are available for the Driver side only. We utilize the cubby compartment for air space and the Sub Box simply slides into place. All that needs to be done to install is to remove the cubby door.
We were able to make it a little larger than our C5/6 boxes, going from .57 to .62 Cf air space. The JL10W3V3 hits hard and sounds incredible. We used the existing sub out put wire (If your Vette did not come with the factory sub you can tap into the rear speaker wire) and used a PAC harness to convert a RCA output for the amp. This allows you to use all your factory audio and makes for a plug and play install. We installed the bass **** on the knee bolster right below the hatch release. The carpet is not an exact match and we are actively looking for a flex form carpet that will match. None of my carpet vendors has anything at this time. The black carpet we used is really close and the lighting from the picture makes the color match worse than it is. The customer of this C7 was very pleased with the carpet match and the sound!
We are also releasing a C7 Partition, VetteBin and Premium Insulation Kit.
We have two options available, one is the sub box or our Complete Turn Key package. Neither options include the 10" JL sub but can be added.
C7 Corner Sub Box $275
C7 Corner Sub Audio Package $622
If you have any questions let us know and will will be happy to assist you anyway we can.
marc@vettenuts.net
615-896-6100
We lost all our install pictures from the one you see above. Our computer problems are your gain!
We are located 45 minutes south of Nashville, TN in Christiana,TN.
