Sponsored by: DashLynx
Convert a Bose radio for use with passive speakers?
Old 03-07-2015, 06:36 AM
Eike
Eike's Avatar
Default Convert a Bose radio for use with passive speakers?
I would like to install a '94-96 Camaro radio, GM #16175961, at a '85 Corvette C4. As the pre-owner tossed all the Bose speakers and amps, I would like to use 4-Ohm passive speakers.
Foune one on eBay. Seller says he can convert the radio to work with 4-Ohm passive speakers:
I CAN CONVERT THE STEREO TO PLAY NORMALLY IN CARS WITHOUT THE BOSE SYSTEM
It should work fine with the 4 ohm. No you would not need amps as the head unit is amplified.
Can it be true? I checked with Doctor Don if they can do such a conversion and the answer is yes. So if two persons state it is possible it should be. The only question is how do they do it? I guess there is not many space in the radio for getting a modern amp in ...
Do you guys think that it will sound any good and will make the same power as a Bose-System?
Old 03-07-2015, 07:05 AM
markcz
markcz's Avatar
Unless you're determined to keep the 'factory appearance' in the car, why not just get an adapter plate to install a new single din radio with all of the modern bells & whistles. It would sound better and most likely be an easier install.
Old 03-07-2015, 03:30 PM
Cruisinfanatic
Support Corvetteforum!
Cruisinfanatic's Avatar
Location: Clifton Park, NY ..............Clearwater, FL ... 85 Original Owner
Because they look like crap???
To Convert a Bose radio for use with passive speakers?
Quick Reply: Convert a Bose radio for use with passive speakers?
