Sponsored by: Innova
Power for C5 Bose replacement head unit?
Old Aug 14, 2002 | 02:00 AM
Steve'01's Avatar
Steve'01
Default Power for C5 Bose replacement head unit?
I have searched and read looking for the wire that controls the switched power on for my new head unit. I have read several good posts here. I have seen the antenna control; I know where the switched power is under the passenger compartment. I ran separate power and grounds off the battery already. I checked all the leads out of the stock harness. I want to use the time delay and window valet to leave the stereo on. I need to understand what powered up the stock head unit. Thanks for the help.
Old Aug 14, 2002 | 12:19 PM
99HT's Avatar
99HT
Default Re: Power for C5 Bose replacement head unit? (Steve'01)
The Boce head unit gets only unswitched +12 volts. Ther BCM sends a data message over the DLC buss to turn it ON/OFF.
Old Aug 14, 2002 | 11:40 PM
Steve'01's Avatar
Steve'01
Thanks for the help. I was hoping that was not the case.
Old Aug 20, 2002 | 12:57 AM
Ten 99's Avatar
Ten 99
FWIW, I don't think you'll be able to use the retained curtousy power function. Most of us just get a switched power from another location. I picked it up near the ignition key switch.
To Power for C5 Bose replacement head unit?
