Sponsored by: Innova
C6 OEM Antenna???
Old Apr 26, 2015 | 10:38 PM
-=Jeff=-'s Avatar
-=Jeff=-
Default C6 OEM Antenna???
I know I have asked some questions before bot I cannot find them now
I know of the design of the antenna, I am curious on the powering and control?
I see there is 2 COAX cable going from it to the radio, which is used?
Then there is a Antenna Enable Signal, I assume it is 12v?
There is a FM Composite signal, I think I read one of this signals being 5v is this 5v?
I am thinking of trying this antenna out, Mine works good, but having a hidden antenna would be nice and being powered might help a bit more
this will be an added project for me to try
Old Apr 27, 2015 | 01:42 PM
markcz's Avatar
markcz
I would try a Metra 44-UA200 before the C6 setup that would most likely cost way more unless you pull one out at a junkyard.
Only one coax goes to the radio, the other goes to the second module box.
The enable signal is 12v.
I never read a definite post for the FM composite signal, but my guess is that the radio varies it from 0-5v depending on the strength of the station it's on. If you do this mod you should be fine with 5v, but only have it on with FM.
Old Apr 28, 2015 | 07:55 AM
-=Jeff=-'s Avatar
-=Jeff=-
looking at a couple C6 set-ups from eBay Etc.. I currently have a power antenna mast, I can keep it and use the toggle switch to turn it on and off, but I miss the older radios that had a separate control for both amps and radio. I have an Android headunit which I do like..
Is the C6 OEM unit really bad?
Old Apr 28, 2015 | 11:15 PM
markcz's Avatar
markcz
It just doesn't seem to do very well with aftermarket radios
Old Apr 29, 2015 | 11:14 AM
-=Jeff=-'s Avatar
-=Jeff=-
ah okay.. I might try the Metra, should be easy to connect and test at least
Old Apr 29, 2015 | 09:57 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
You buy a new toy
Old Apr 29, 2015 | 10:45 PM
-=Jeff=-'s Avatar
-=Jeff=-
I wish.. No just looking at options for hidden antennas
To C6 OEM Antenna???
