Sponsored by: Innova
C7 speaker replacement using LC6i...part 2, pics
Old Jun 3, 2015 | 10:40 PM
Slomo051's Avatar
Slomo051
Default C7 speaker replacement using LC6i...part 2, pics
Here are a few pictures...I took these before I cleaned up the wire routing/wrapping, etc. This gives you a general idea of location and room I had to work with.
Old Jun 3, 2015 | 10:50 PM
Slomo051's Avatar
Slomo051
Default More pics of C7 install
This picture is of the X2 (green) harness and how I tapped into the wires using "posi-tap" connectors. I also used and labeled shrink wrap to identify every wire I ran for the install...
I also tapped into X1 connector (black). These are for the door woofers...forgot to mention the X1 in the original thread.
For grins...I tapped into the subwoofer feed and tested with a sub I had laying around. It a good signal. I will install a Sub and DSP soon.
Old Jun 3, 2015 | 10:54 PM
Slomo051's Avatar
Slomo051
Default Pics continued
This pic is of the tweeter...note how it pretty much "snaps" in the OEM location. These are 1" tweeters.
Old Sep 12, 2015 | 06:39 PM
jonparks's Avatar
jonparks
The Black and yellow/yellow is mislabeled in the schematics. It should be yellow/Light Blue yellow. I did the same thing shown in your photo but could not get a signal. Looks like all of the speaker wires are on the green connector.
Thank you very much for the info!
To C7 speaker replacement using LC6i...part 2, pics
