Newsmy NU3001 in a C4
#41
so no pre-amp needed.. It was an odd issue with the tuner.. I had a bad cable for the tuner causing issues. I made a custom OTG cable I need to test, I also need to relocate the Shield until I am happy it is working good.
I pulled the Shield and Arduino out Friday to resolve some issues ( and found the bad cable)
I need to reinstall, but need to add longer wires for the relocation
#42
I wanted to post an update to my thread..
I switched to a joying UL135 last year as I really missed a volume ****, the new unit has one, but has some other issues. I am not happy with being forced to use he Default music player by pressing the source button, there is no way that I know of to change it..
Anyway, I have begun to mess with the NU3001, since I plan on adding a MiniDSP and it has a selector and volume control, I may be going back to the NU3001. I do have a USB volume control that works well with the NU3001 so I have a couple options and might add it and try it again.
This time I will add a external switch to control the HDtuner switched power. if I power on the HU then the HDtuner is seems to be pretty stable.
I am getting spoiled with HD radio in my daily so I would like to have it in my vette if I can, I found the UL135 does not work well if at all with the HDtuner stuff I have
