I have a 2001 coupe ,when i turn the fade **** from the 12o'clock position to 3 o'clock nothing happens :mad when i turn from 9o'clock position to 12o'clock the rear speakers come alive. should I take it back to the dealer? i'm afraid they will want to tear the interior apart! Anyone know what is wrong or how I can fix it? thanks inadvance!! :chevy
Could be any # of things. From bad headunit fader **** to faulty output, to bad connector, best bet is to see if dealer can swap headunits to narow problem down, sorry for advice but it's all I can give.
tkbillg...your stero is OK. You have the upgraded Bose system. When you speed up the sound increases. That's why you have that adjustment tuner behind the volume ****. It's all in your service manual. :yesnod:
I have the same Bose system too. As I punch the gas petal so goes my volume too. :yesnod:
Re: what's wrong with bose system? (BodaciousBlue)
I know all about yjr variable volume control on the volume comtrol,but when i turn the "fade" **** nothing happens between 12 and 3 oclock ,,,maybe I should not listen to my radio between 12 and 3!? :lol: :lol: :D gonna take it to the dealer!!
