Sponsored by: Innova
GrandSport Bose Door Subs
Old Sep 13, 2015 | 01:58 PM
RC4G's Avatar
RC4G
Default GrandSport Bose Door Subs
So I had to replace my driver's door sub in my wife's 2012 GrandSport CE. It had the same separation of the foam driver from the rear metal ring I've seen other posts about.
I was under the impression that all Bose door subs had the amp built on to the speaker making it challenging to do aftermarket replacements but when I removed the speaker there is no amp on it.
My dealer actually had a replacement sub in stock and although it was not the same part # as the one I removed (and not a direct supercession) it also did not have the integrated amp.
I seem to remember reading that GM made a change to the BOSE premium sound system for the 2012 Grandsports/Z06. Did this change include going to a centralized amplifier solution for the doors instead of dedicated amps integrated into the speakers themselves?
Old Sep 13, 2015 | 04:57 PM
bartsky's Avatar
bartsky
I think the amp is in the passenger footwell.
Old Sep 13, 2015 | 06:24 PM
markcz's Avatar
markcz
The integrated sub amps went away when they went to the 9-speaker setup with dash tweeters, either 2010 or 2011 model. They are now powered from the same amp as all the rest, and it is in the footwell to the left of the fuse box.
Old Sep 14, 2015 | 11:38 AM
RC4G's Avatar
RC4G
I'm almost positive my 2011 GrandSport has the integrated amp on the door sub so I'm thinking that was a 2012 change.
Old Sep 16, 2015 | 08:49 PM
Sky High's Avatar
Sky High
Yes the change to 9 speakers occurred in 2012
Old Sep 18, 2015 | 12:48 AM
Gadfly's Avatar
Gadfly
I have a 2012.
Does this mean it is easier to upgrade the factory speakers?
Old Sep 18, 2015 | 01:06 PM
markcz's Avatar
markcz
Originally Posted by Gadfly
I have a 2012.
It isn't any harder or easier, but IMO when they added the dash tweeters it made the simple 2-way swap out pointless. OEM is now on par with the 'simple' upgrade.
However, for my money, removing entire door setup to install amped components and a real sub in the trunk is still very worth it.
To GrandSport Bose Door Subs
