Sponsored by: Innova
Got speakers installed, Head unit problems
Old Aug 25, 2002 | 05:33 PM
Ender85's Avatar
Ender85
Default Got speakers installed, Head unit problems
I got 4 pioneers (4" in front and 6 x 9 in the back) installed and wires running to the front. I also have a Pioneer head unit. Here's where the problems start. The previous owner of my car had an intricate Alpine system installed and cut it out when I bought the car. So now there are a bunch of random wires sitting there and I don't know what to do with them. I thought that the only wires I need to install would be: 4 wires (one each for the speaker) 2 power (one for car on, one for all the time) and the power antenna plug in thing. Now I have no idea what to do because I can't figure out which wire is what power and I am completely clueless about the power antenna setup. I'll try to take a picture of it and get it up here soon - what should i DO?
thanks
marthpodi
Old Aug 25, 2002 | 09:30 PM
Kale's Avatar
Kale
Default Re: Got speakers installed, Head unit problems (marthpodi)
Run new wire to the speakers. Run the + to teh battery, and - to good ground. There, most of that is taken care of.
The generic color for Power-Antannae is blue... i think it might be blue/white in the vette.. dont take my word for it
Old Aug 25, 2002 | 10:54 PM
Ender85's Avatar
Ender85
Default Re: Got speakers installed, Head unit problems (Kale)
I have run new wiring to the speakers. But what color is power? Or should I run a new power wire somehow? also, aren't there 2 power wires? Also, i have the power antenna plug, but dont I need to run power to the antenna as well?
Old Aug 25, 2002 | 11:56 PM
Kale's Avatar
Kale
You should always run new power and ground directly to the battery when installing an aftermarket head unit. I don't recall the Corvette color for antannae, sorry :(
Old Aug 26, 2002 | 01:17 AM
_Nomad_'s Avatar
_Nomad_
From: Frankenstein never scared me. Marsupials do, because they're fassst…and they DART, THAT'S crazy!
Here you go marthpodi, this site will give you the wire color codes for your Vette.
http://www.corvetteradios.com./Page3.html
Old Aug 26, 2002 | 09:24 AM
92TripleBlack's Avatar
92TripleBlack
Default Re: Got speakers installed, Head unit problems (The^Nomad)
Run to the harness that was cut, not the battery. You may have some blown fuses also. These are located behind the carpeted panel above the passenger's feet. Hook up constant+, Ignition +, ground-, Power antenna, Lights, and 4 sets of speaker wires(each with a postitive and a negative) Since you are using your own wire, put the wire with the writing on it to positive. This way you don't mix them up from front to back. I also tie a knot in the driver's side wire when I run both so I know what is what after running them together under the carpet front to back.
Old Aug 26, 2002 | 08:27 PM
Ender85's Avatar
Ender85
Default Re: Got speakers installed, Head unit problems (92TripleBlack)
okieday, thanks guys :cheers:
To Got speakers installed, Head unit problems
