Sponsored by: Innova
99 FRC system install (pics)
Old Feb 28, 2016 | 07:15 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
Default 99 FRC system install (pics)
Just picked up a mint 99 FRC and the first order of business was a mild stereo upgrade
99 FRC
Headunit: Alpine 9886
Amp: Elemental Designs Nine.4
Components: JL Audio CS-650
Baffles: homemade
Subwoofer: undetermined at this time but most likely 2 8's in corner boxes
Also have a shorty antenna, eBay Bluetooth module, LEDs under dash, and 2 LED bolts in trunk for illumination
Also installed a Viper 211 keyless entry system due to the high cost of remotes for the older cars
FRC on the way home from NewYork
Driver side speaker and tweeter installed, crossover is under the dash on their respective sides. Above the speakers you can see the lock, unlock, and disarm wire ran into the door of aftermarket keyless entry. My factory fobs weren't working and I was able to put a viper unit in with two remotes for 25 dollars versus new remotes with limited range for far more money.
Passenger side speaker
One of the crossovers mounted under the dash
Amp mounted under the passenger seat, it really should be a little bit further forward as the bottom of the back of the seat will hit it unless all the way back, it made getting the seat in a bit tricky. 6 foot rcas feed it from the head unit. Front components are ran off of two of the channels, and the reads are bridged for the sub. 8ga power coming from the auxilary stud under the hood, and grounded next to the seatbelt retractor deal under pillar.
View of the amp from the front of passenger seat
First power up of the head unit. Grabbed dimmer wire from hvac unit power, accessory, and ground all pulled from the 3 wire connector in passenger floorboard.
Bought one of these 10 dollar eBay special Bluetooth modules and put it in a small enclosure and wired it into the head unit and hid it behind the dash for Bluetooth audio.
Dash put back together
Shorty antenna
LED bolts installed in the trunk. Being an FRC it doesn't have trunk lighting so I added these as a low buck alternative. Work awesome and look very much stock but the pictures don't do it justice.
Still breaking in the speakers and dialing the system in but it sounds great for a low buck setup. I literally had everything already except the speakers which Dennis at DD Mods hooked me up with. Currently just have spare 8" sub in center cubby until I figure out a permanent setup. Sounds 100x better then stock and very stealthy install which is what I was going for.
Old Feb 28, 2016 | 09:26 PM
firemailwv's Avatar
firemailwv
nice. Proves it doesn't take big bucks to put together a useful system.
Old Feb 28, 2016 | 10:36 PM
markcz's Avatar
markcz
Nice! Sometimes budget builds are the best ones
Right now I'm sitting in my hotel room 6 miles from the NCM. I'm doing R8C on a new coupe tomorrow, so I'll be starting over in a C7 soon
BTW, who's the dude in your rear window
Old Feb 29, 2016 | 09:03 AM
civi's Avatar
civi
Shorty antenna
Chive on! Nice install!
Old Mar 3, 2016 | 06:29 PM
jcgunn's Avatar
jcgunn
Nice job! I have always liked the FRC. ...but Miller High Life, really!
To 99 FRC system install (pics)
