Sponsored by: Innova
Alternate Antenna C4?
Old Sep 3, 2002 | 12:23 AM
Zpeedstr's Avatar
Zpeedstr
Default Alternate Antenna C4?
My antenna ejected. I have removed the whole power antenna unit (3 lb. savings).
The interim antenna is the rear window defroster. Not quite as good as the old unit.
Has anybody had success with alternate antennas inside the body/roof/window envelope?
r
Old Sep 3, 2002 | 12:25 AM
92TripleBlack's Avatar
92TripleBlack
Default Re: Alternate Antenna C4? (Zpeedstr)
If you want to save weight, use a standard shaft antenna. Window, etc antennas never had good reception. You need a 31" verical shaft to be popular and have good reception. ;)
Old Sep 3, 2002 | 03:57 AM
gcrouse's Avatar
gcrouse
I'm using this Radio Shack "antenna tape" stuff on the inside of my windshield; goes up the right side then across the top. My reception is fine but I'm in metro Phoenix; kind of depends on the distance you're trying to pull signals in from.
I've also had good luck on a TransAm (previous life) with a flexible shorty antenna; 17" or so, black- about the best looking fixed antenna you'll find.
Old Sep 3, 2002 | 06:20 AM
_Nomad_'s Avatar
_Nomad_
From: Frankenstein never scared me. Marsupials do, because they're fassst…and they DART, THAT'S crazy!
Default Re: Alternate Antenna C4? (92TripleBlack)
You could make a fortune in the movies with that too! :eek: :lol: :cheers:
To Alternate Antenna C4?
