Sponsored by: Innova
Os2x
Old Mar 9, 2016 | 04:16 PM
lucas111's Avatar
lucas111
Cruising
Default Os2x
Hi,
• I’ve ordered 1 PAC OS2X Radio Replacement Interface with Onstar Retention for Select GM Class II Vehicles, but I can’t connect to my radio (Rupse For Hummer H3/Buick Terraza/Chevrolet Corvette Uplander/Pontiac/Saturn Relay 7" Touchscreen Monitor Car DVD Player With GPS Navigation System 2 Din)
• I have a Corvette C6 from 2005
• Included the photo’s : I need a cable between the blue box and the radio…….?
• Thanks
• Mvg
• Luc
Old Mar 10, 2016 | 09:59 AM
markcz's Avatar
markcz
The interface adapter should have a wire harness with loose wires on it. Connect those wires to the loose wires of the radio. Pretty much color matching, just verify that with the instructions.
Old Mar 10, 2016 | 11:31 AM
lucas111's Avatar
lucas111
Cruising
THis is what I have now / see photo please
Old Mar 10, 2016 | 12:08 PM
markcz's Avatar
markcz
Connect the wires in the circles to each other.
I'm not sure what's going on with the plugs on the end of the radio wires, you may need to cut them off if they are the speaker output wires.
Old Mar 10, 2016 | 12:28 PM
lucas111's Avatar
lucas111
Cruising
Or I use the cable delivered with the radio? when I connect it with the car, there is no power on the radio........
Old Mar 10, 2016 | 12:46 PM
markcz's Avatar
markcz
Look at the instructions for both the OS2X and the HU.
At a minimum, the OS2X needs red, black, yellow, blue/white, and all of the speaker wires connected to the proper HU wires.
Red, black, yellow will power the radio and turn it on/off with the car.
Blue/white will allow radio to trigger on the stock amp.
Speaker wires allow you to hear music.
HU dimmer wire needs to be connected to gray/black wire at TC/AH button on dash.
Old Mar 10, 2016 | 01:14 PM
lucas111's Avatar
lucas111
Cruising
so,
I need to cut off the black connector and connect yellow, red and black cables between OS2X and radio? and then the other cables, green, blue etc
Old Mar 10, 2016 | 01:53 PM
Klaus-96's Avatar
Klaus-96
2019 Z06 2LZ A8 Coupe
I advise caution. It appears this radio is marketed as plug and play. I suggest you contact the seller for help before cutting any wires.
Here is the radio on Amazon:
Amazon.com : Rupse For Hummer H3/Buick Terraza/Chevrolet Corvette Uplander/Pontiac/Saturn Relay 7" Touchscreen Monitor Car DVD Player With GPS Navigation System 2 Din : Car Electronics Amazon.com : Rupse For Hummer H3/Buick Terraza/Chevrolet Corvette Uplander/Pontiac/Saturn Relay 7" Touchscreen Monitor Car DVD Player With GPS Navigation System 2 Din : Car Electronics
Old Mar 10, 2016 | 02:32 PM
lucas111's Avatar
lucas111
Cruising
plug and play, but it doesn't work, radio stays dead.......that's the reason I ordered the OS2x
Old Mar 13, 2016 | 11:52 AM
markcz's Avatar
markcz
If you have the wiring diagram available for the new HU you can connect it with the interface adapter just like any other radio, but I'd work on making it work the way it's supposed to first.
Just to do a test on it, connect both red and yellow power wires to +12v and the black wire to ground, it should turn on. Of course that assumes there is a red wire, it may just use the serial data line to trigger on if it's made specifically for GM cars
If you can return it, I'd suggest a Kenwood or Pioneer
Old Mar 14, 2016 | 02:26 PM
lucas111's Avatar
lucas111
Cruising
I've connected all the loose wires and it works! so thanks guys!
Old Mar 14, 2016 | 07:47 PM
markcz's Avatar
markcz
To Os2x
