Sponsored by: Innova
88 Bose Conversion
Old Sep 3, 2002 | 04:38 PM
Tourney3p0's Avatar
Tourney3p0
Default 88 Bose Conversion
Hey guys. Sorry to bother you again.
I have a couple of questions I need to clear up before I go make my purchases for a new audio system.
First of all, I bought a Pioneer DEH-6400 HU. I know that without an adapter, my stock Bose system will not work, and even with the adapter it will be less than optimal.
I'm looking for sizes, etc on existing equipment so I can start looking for equipment to replace it. For example, it looks to me like my rear speaker mount can take some 6 x 9's, but it has 6 and a halfs in it. Is this right? And if that's the case, will I run into any problem if putting 6 x 9's in instead?
I haven't gotten into my doors yet, but it seems like I saw somewhere in the forums that it has 5.25's in it. Is that right? And if it is, do you suggest staying with 5.25's or go to something different?
It seems like I also saw somewhere in the archives that my dash speakers are nonexistent even though I have the stereo grilling in the dash. I think I confirmed it by changing the focus to the front speakers and giving it some volume. Is it really empty in there? If it is, I plan on leaving it empty.
I don't want anything big and elaborate.. I'm only changing it in the first place because I want a CD player and I know I can't use my other Bose equipment with it. I'd like to put an amp in as well. Nothing big, maybe 75x4.. this would work out well for me if I had no front dash speakers.
Some cheap but capable recommendations would be appreciated, but I'm mostly looking for sizes and stuff. Thanks much.
Old Sep 3, 2002 | 08:13 PM
_Nomad_'s Avatar
_Nomad_
From: Frankenstein never scared me. Marsupials do, because they're fassst…and they DART, THAT'S crazy!
Default Re: 88 Bose Conversion (Tourney3p0)
Your rear Blose speaker pod holds a 4” speaker same as the door pod does. Just remove the entire Blose pod and you will have a 6x9 plate there you can mount a 6x9 speaker too. Very simple procedure.
The door Blose pods have 4” speakers in them. You can put 5.25” speakers in the there with minor cutting to the pod.
Yes, the dash is empty; it has no speakers there if you have the Blose system. The speaker locations in the dash are for the non-Blose stereo system option. You can easily cut the plastic facing and be left with a 4x6 speaker mount. You could put some 4x6 plate speakers in there and, combined with door speakers, will help with staging up front. You really need something up at dash level.
Adding an amp like that would be a good idea. However, you still might want some dash speakers, they don’t necessarily have to run off the amp. You could have the 5.25” doors and 6x9 rears run off the amp and the 4x6 plates in the dash run off the HU.
That would be a very simplistic, non-elaborate stereo system that should yield decent sound quality. Of course, in the not too distant future you will probably want to add some subs to that, but that’s another post. ;)
Thanks much.
Your welcome. :D :cheers: :seeya
