Sponsored by: Innova
C6 Head unit install (from BOSE) tutorial?
Old May 15, 2016 | 11:18 AM
corrado's Avatar
corrado
2021 C6 of the Year Finalist - Modified
Default C6 Head unit install (from BOSE) tutorial?
Just got my Kenwood 373 head unit from Dennis at DD this week! Going to tackle the install soon but cannot find the tutorial on installing the head unit only. I see a few of them on here, but not exactly what I am looking for, maybe I am searching wrong.
If any of you know what to search for or point me in the right direction I would be extremely greatful!
Old May 15, 2016 | 03:42 PM
Hajie c6's Avatar
Hajie c6
Default Hu
I am taking my car in to manny next weak. For a head unit install. Idid my Yukon but these corvette is a PITA. To much electronics . I will let you know how it turn out.there is a bunch on here but not to full detail. If I come across one I will let u know . Hajie
Old May 16, 2016 | 12:34 AM
markcz's Avatar
markcz
There isn't much to a HU swap.
Best console removal instructions are HERE, click on Step 1 for C6, just ignore the shifter specific info. Once you have the plastic center dash off all you need to do is unscrew the HVAC and stock radio. When reinstalling new HU and HVAC make sure to put screws in almost tight on both, then push up towards AC vents with HVAC module before tightening screws down or you may have issues with the ash tray binding.
Once old radio is removed just follow BOSE instructions for the interface adapter that you have (even if your car is non-Bose, follow the Bose instructions), with a few exceptions based on what adapter you have....
Connect HU orange dimmer wire to gray/black wire under TC/AH button.
If you're installing a reverse camera, post 2 of this thread shows where to find reverse trigger in the fuse box area.
Make sure you connect HU blue/white trigger wire to interface adapter or you won't hear squat when you turn it on.
Post here if you have any questions
Old May 16, 2016 | 05:29 AM
corrado's Avatar
corrado
Thank you Markcz!
I'll let you know how it goes once I get some time to install it. I can't wait to get rid of the very dated stock Bose unit.
Old May 18, 2016 | 06:11 PM
Marco Matos's Avatar
Marco Matos
Interested in outcome, I plan on doing it too in a few weeks. Plan on using:
PAC RP3-GM11
Metra 95-3304 Double DIN Installation Kit
Infinity Basslink
Pioneer AVH-X4800BS
Keep Factory Bose speakers. No Onstar system, no Steering Wheel controls on my 2006 Z06. Bought it a few weeks ago!
Any comments?
Old May 19, 2016 | 01:16 AM
markcz's Avatar
markcz
Originally Posted by Marco Matos
Plan on using:
PAC RP3-GM11
Any comments?
DO NOT cut the RCA's off of the RP3, use the Bose instructions regardless of what is in your car.
Old May 19, 2016 | 10:22 AM
corrado's Avatar
corrado
Installed it yesterday!
Didn't realize Dennis has a thread on exactly what i needed, on page 2. Don't know how I missed it, I must be getting old.
Actual Head unit install is fairly simple, it's taking the console apart with all the connectors that is a bit of a pain. Just take your time.
New Head unit is AWESOME! You don't realize how prehistoric the stock GM unit is until you replace it. (perhaps I was in denial, should have done this years ago!!) Sound is better, even with stock speakers. I wanted an updated look, with Bluetooth, USB, etc and the Kenwood works great. Still have to play with all the settings, but did the basics, (Bluetooth pairing, USB, etc. pretty easy to figure out although there's TONS of settings so it will take time to get it perfect I guess.
I want to thank Dennis from Double D Mods! I called him a few times and ALWAYS helpful (and patient!) I have always read only good things about Dennis on this forum so I knew when it came time to do something about my sound system I would go to him. A good company is about more than selling good equipment, the customer service is equally important. I highly recommend him to anyone!
To C6 Head unit install (from BOSE) tutorial?
