Sponsored by: Innova
Working with Vinyl ????
Old Sep 9, 2002 | 06:39 PM
MY2K2C5's Avatar
MY2K2C5
Default Working with Vinyl ????
In doing my researching I have ran across quite a few pics of amp racks, sub enclosures, etc. covered with vinyl. I have read that they heat the vinyl with a heat gun to get it to form to the shape desired. This is all good and understood...I think... :D
I am wondering if the vinyl is glued down or how it is attached to the mdf or other material you are using? Is it glued and then heated? What is the best way to work with this monster?
Thanks, :confused: :sleep: :confused:
Old Sep 9, 2002 | 06:41 PM
Kale's Avatar
Kale
Default Re: Working with Vinyl ???? (MY2K2C5)
I use 3M high strength glue as found at Home Depot for $11.99
Old Sep 9, 2002 | 06:45 PM
MY2K2C5's Avatar
MY2K2C5
Default Re: Working with Vinyl ???? (Kale)
Ah, would this be the spray adhesive that is also used for carpeting? If so do you apply after you have heated the vinyl and formed to shape or prior to heating and shaping?
Thanks,
Old Sep 10, 2002 | 06:40 AM
Audiowizard's Avatar
Audiowizard
I have been working with vinyl for years and it takes some practice to get it to stretch with-out wrinkles. I am a little different on the glue, I use Weldwood contact cement to glue vinyl down and its the only thing that I have used that wont "lift" in extreme temperatures especially since I live in one of the hottest parts of the country!
Old Sep 10, 2002 | 01:19 PM
Kale's Avatar
Kale
Default Re: Working with Vinyl ???? (Audiowizard)
Any suggestions on doing the A-pillars in black vinyl on an early c4? I've only done box tops so far.
Old Sep 10, 2002 | 02:05 PM
Audiowizard
I would suggest purchasing some vinyl with-out backing that stretches very well and you can use a heat gun to get out the wrinkles. One of the places that I had seen that vinyl was at http://www.thezeb.com I know there are others but I dont remember the links.
Old Sep 10, 2002 | 02:48 PM
Audiowizard
Here is a set of custom door pods that I built for a customer in Illionois with the Harley Davidson seat vinyl with backing. Its a little harder to work with than vinyl without backing but since I dont have sharp corners, it works just fine. for sharp corners, I would recomend the un-backed vinyl for the A pillars that have sharp corners.
Here they are before I dyed the vinyl to match the lower door panels.
Old Sep 10, 2002 | 03:01 PM
Kale's Avatar
Kale
Nice work :cheers:
Old Sep 10, 2002 | 03:10 PM
Audiowizard
Nice work :cheers:
Thanks for the kind words :) .
Old Sep 10, 2002 | 03:37 PM
MY2K2C5's Avatar
MY2K2C5
Looking good man!!!!!! :cool:
So I guess that I am going to have my work cut out for me then... oh well the things that I always want seem to come at some sort of a price... :cry
It appears that I will have a bit of a time since I am going to be doing it during the winter months. I will try to keep the garage as warm as possible I guess... Can use one of our heavy duty heat guns from work..
Any other tips or advice would be appreciated...
Old Sep 10, 2002 | 05:41 PM
YO-EL's Avatar
YO-EL
Vinal amprack as compared to more forgiving carpet.
[Modified by indypace78, 4:44 PM 9/10/2002]
Old Sep 10, 2002 | 06:00 PM
Audiowizard
Thanks man!
You need to have the garage temperature at least above 75 degrees because glue will not bond as well below those temperatures and make sure that the humidity level is low, that is another thing that will not make the vinyl bond to the glue. The air temperature is critical for the glue and vinyl to work so I would recomend a Kerosene forced heater which will keep everything nice and toasty and use the heat gun to keep vinyl warm and pliable. :)
I would take a piece of scrap vinyl and practice on the A piller piece before you make the vinyl permanent. Its actually gets easier every time you do it because you learn what and what not to do. I am sure you will have good luck with your project.
To Working with Vinyl ????
