Sponsored by: Innova
C6 Bose issue
Old Aug 10, 2016 | 09:14 PM
markcz's Avatar
markcz
Is it the 3.5", the subs, or both, and how much will they charge?
Old Aug 10, 2016 | 09:26 PM
emfollin's Avatar
emfollin
They quoted over $400 each so I'm assuming it was the powered subs after doing some research on OEM speakers. If that is the issue, why would the rear speakers have static too?
Old Aug 11, 2016 | 07:29 PM
markcz's Avatar
markcz
I suppose it's possible that a bad speaker could put the amp into some type of protection mode, causing it to shut down, but what you were describing didn't sound like that.
Have you considered upgrading to aftermarket amp/speakers? You can get a pretty good sounding setup for under $1000.
If you don't want to upgrade, at least try to find some take-off speakers on the forum
Old Aug 11, 2016 | 08:37 PM
emfollin's Avatar
emfollin
$1,000 too much for me. I can get used speakers off here for about $100 so I'm going to try to replace the door subs.
Old Aug 12, 2016 | 02:06 PM
Sox-Fan's Avatar
Sox-Fan
I am late to the party, but this recently happened to me. I did notice that if I hit a bump it would momentarily clear up. Took the door panels off and found no loose wires but in the course of messing with it I somehow ended up with my knee against the amp on the driver's side and it cleared the sound up. took my knee off, and it went crackly and weak. turned out the two philips head screws that hold the amp to the speaker had loosened. Tightened the two of them, and the passenger side too, and now the speakers sound good again.
Old Aug 12, 2016 | 02:20 PM
emfollin's Avatar
emfollin
So you had the same symptoms as me? Did you notice the crackling from all speakers or just the door subs?
Old Aug 12, 2016 | 04:53 PM
Sox-Fan's Avatar
Sox-Fan
Just the door subs only. The rear speakers (which were no longer bose when I got this car) did not exhibit the issue, neither did the center dash speaker or the door tweeters. The big door speakers would crackle and make terrible sounds until I hit another bump, then they would either go out, or slip down to very low volume.
We took the door panels off to see what other speakers might fit as I assumed they were blown because of the crackling noises. It was by accident that I found that the two screws that hold the amps in place had come loose. As soon as those screws were right everything sounded just as it should. Who would have thought? Give it a check. Heck you have nothing but 6 or 7 minutes to lose, right?
Old Aug 12, 2016 | 06:10 PM
emfollin's Avatar
emfollin
Yeah I'll check it out but I don't think that's my issue since all my speakers are doing it when I adjust the fade and balance.
Old Aug 12, 2016 | 08:53 PM
emfollin's Avatar
emfollin
So I pulled the door panels off and disconnected all door speakers. The dash speaker and rear speakers still sound horrible. I wouldn't think the door subs would be the problem per the dealer???
Old Aug 25, 2016 | 07:31 PM
emfollin's Avatar
emfollin
Surprise surprise it was not the speakers.
Old Aug 28, 2016 | 09:21 PM
markcz's Avatar
markcz
....each and every speaker produces the same static when adjusting the fade and balance.
Assuming everything else was done correctly, that just leaves the radio
Old Aug 28, 2016 | 09:38 PM
emfollin's Avatar
emfollin
Having new touch screen installed next Saturday.
Old Aug 28, 2016 | 09:46 PM
  #33
markcz's Avatar
markcz
I hope it wasn't expensive, you can get a nice aftermarket Nav unit for about the same as a stock radio.
Old Aug 29, 2016 | 07:51 AM
  #34
emfollin's Avatar
emfollin
Nah went with an aftermarket Bluetooth touch screen without navi. I can get a refund less labor too if this doesn't fix it. However the only next step would
mosy likely to be to install a whole new system bypassing the Bose amp.
Old Sep 3, 2016 | 05:35 PM
  #35
emfollin's Avatar
emfollin
Finally have closure. The new radio fixed it. I think I still hear some feedback in the door speakers but the sound is back and ready to roll.
Old Sep 5, 2016 | 10:39 PM
  #36
markcz's Avatar
markcz
Old Oct 17, 2016 | 10:05 PM
  #37
emfollin's Avatar
emfollin
ok so I now have the JVC Touchscreen installed with a harness through the Bose ampand speakers. Sound has been restored. However, over bumps and sometimes just randomly, especially right after startup like leaving the driveway, the speakers still pop a little. Is this a setting? Ground? Bad speakers?
