Sponsored by: Innova
My Subwoofer Box
Old Oct 16, 2016 | 04:38 PM
TheProsecutor's Avatar
TheProsecutor
Default My Subwoofer Box
Hello,
I thought I would post my subwoofer box pictures.
1. c5 Z06/FRC Corvette Partition Subwoofer Box
a. .71 cubic ft. sealed box
b. .71 cubic ft. sealed box, empty, carpet uncut, room for future 10W0v3-4
2. JL Audio 10W0v3-4
Old Dec 1, 2016 | 06:48 AM
druz06's Avatar
druz06
Nice! I am considering one of those or a rear center box. Was this DIY?
Old Dec 1, 2016 | 07:28 AM
TheProsecutor
Yes, it is DIY. The subwoofer hole is already cut out. The terminal cap is in place. All I had to do was wire the subwoofer, then mount the subwoofer with 8 screws. Connect the the amp via terminal clips and it is good to go.
I remove the box easily when I track the car.
I bought another JL 10" subwoofer on Black Friday. I will add the subwoofer by cutting the carpet with a razor knife. 8 more screws, another wire.
FWIW, it also acts as a sound barrier to the trunk, which can let a lot of road noise in.
It is a partition and a sub box.
Old Dec 2, 2016 | 02:16 PM
95wht6spd's Avatar
95wht6spd
Very nice. Did you buy or make the center hole cover for the floor?
Old Dec 2, 2016 | 08:14 PM
TheProsecutor
The cover is stock. At least I assume.
Old Dec 2, 2016 | 10:24 PM
95wht6spd's Avatar
95wht6spd
I don't think so. I have an 02Z and mine doesn't have one. I may have seen one like it before, but most just have the open hole. It looks stock, and I like that, good to make a flat bottom for things and to store something.
Old Dec 3, 2016 | 11:10 AM
druz06's Avatar
druz06
Did you build a box onto a partition? What else are you running for your whole audio setup?
Planning mine out.
Old Dec 3, 2016 | 05:10 PM
TheProsecutor
Planning mine out.
Kenwood Excelon DDX492 - 6.2" touchscreen
Kenwood KAC-6406 500 Watt 4/3-Channel Amp
Kenwood 6.5" seperates in door.
JL Audio 10w0v3-4 subwoofer. Soon two be two.
I will take some pictures.
The retailer is not a sponsor of the forums
Google "C5 Z06/FRC Corvette Partition Subwoofer Box"
MDF Construction and is 19 lbs
The box installs between fender wells and slides into place.
Sub box doubles as a partition to seal off trunk area.
Subs fire forward into cabin. Fits One or Two 10s or Two 8" subs
Mounting Depth: 6.75"
Volume: .71 cu.ft. ea. dual or up to 1.4 cu.ft single
Sealed Box, separated chambers
Old Dec 4, 2016 | 08:12 PM
druz06's Avatar
druz06
Thanks nice to see how deep it looks too. I looked at that box vs the partition and the center sub box. Still on the fence just like what components but similar to you-fronts and sub.
Old Dec 4, 2016 | 09:25 PM
TheProsecutor
Today, I attempted to add a second amplifier. I have a ground loop. A high pitched whine that varies with RPM. I don't want to go with a GLI. I heard it alters the sound quality.
I am thinking of installing a ground wire to the the frame. I wish there was closer one than the grounding point by the door, under the seat belt bolt.
Old Dec 4, 2016 | 09:31 PM
druz06's Avatar
druz06
I am planning a 5 channel to use on components and sub(s) making it less hardware. I heard a few adding another ground from the cylinder head to the frame-which ever was not. Aside from the Big 3 wiring I will likely do also,
Old Dec 6, 2016 | 11:15 PM
TheProsecutor
I removed the second amp. I could not lower the ground loop noise. Ugh, 40 watts per sub is way too quiet. I need a new amp.
Old Dec 7, 2016 | 06:55 AM
Jimnc's Avatar
Jimnc
Try the GLI. Cheap, easy fix. I did not notice any degradation to the sound quality.
Old Dec 7, 2016 | 07:53 PM
druz06's Avatar
druz06
my thoughts too I figured before or after sound deadening, loud exhaust and just running nigh watt components I'd need w power
Following your progress.
Old Dec 7, 2016 | 09:09 PM
TheProsecutor
Old Dec 11, 2016 | 07:30 AM
druz06's Avatar
druz06
Sorry for more questions but is it too boomy etc behind your head? Really like this setup/enclosure.
Has the GLI solved your problem?
Old Dec 11, 2016 | 10:53 AM
Jimnc's Avatar
Jimnc
Bass is non directional. I have a 10" JL stealthbox. You feel the bass more than hear it.
To My Subwoofer Box
Old Jan 5, 2017 | 11:14 PM
Dave70's Avatar
Dave70
I like it.
Old Jan 7, 2017 | 04:06 AM
gymdoc's Avatar
gymdoc
the stealthbox is badass.. and you loose no trunk space..
Old Jan 14, 2017 | 02:19 PM
Dave70's Avatar
Dave70
no room for the tray that goes on the shelf. i wonder if the 8" subs would have room to clear it.
