Valentine 1 Radar Detector Story - Extremely Unsatisfied
Received 2,093 Likes
Also, and this was a big help for me, check out some of the radar detector forums. Those guys are really into it and can fix you up.
1) You can enable the new Junk K Fighter which does a great job at filtering out false alerts from many nearby cars with blind spot monitoring systems.
2) Buy the Bluetooth module and pair it to your phone. There's third party apps available, V1Driver for iOS and YaV1 for Android, which will learn all the stationary false alerts you'll encounter from drugstore automatic door openers and speed signs on the side of the road. It will remember where those are located and tell your V1 to keep itself quiet when it comes across a known false alert.
Those'll handle both moving and stationary false alerts for you. There's other benefits too like you can enable custom sweeps to improve the performance and so on.
If you google around, there's tutorials available to help you set it all up and program it.
With an older V1 though, unfortunately your options are very limited.
Corvette Enthusiast
X band is mostly useless now, and K band is getting there. Junk K Fighter is basically a "delay" in the K band getting broadcast to you. Since most false alarms are a BANG of full on radar that's how they filter. The problem is if the cops in your area use POP you are basically screwed as the detector won't catch those in time.
Someone mentioned turning laser off, which you can do, as laser is basically for information only, 90% of the time you're already nailed (unless you get a lucky lucky bounce or its a false alarm).
