forum member Mike76002 has helped me out tremendously and is going to build me two small enclosures that will fit in the side compartments. My NOS bottle and CD changer are in the middle compartment.
Is there a brand of sub that would have enough air space to fit 10's in these two small areas or should i just go with 8's in each side?
Re: side compartments enough space for a 10"? (NYtoCA)
IT DEPENDS ON HOW FAR OUT HE BUILDS THE ENCLOSURE & WHAT TYPE OF BASS ARE YOU LOOKING FOR :confused:
I THINK THE 8'S WOULD BE EASIER TO WORK WITH. IF YOU DECIDE ON 10'S YOU MIGHT WANT TO CONSIDER INVERTING THEM. IF THE CORNERS ARE FIBERGLASSED FILLED OUTWARD THEN INVERTED 10'S ON AN ANGLE WOULD BE A FIRST AND :cool: :cool: THIS WILL ALSO ALLOW FOR A LITTLE MORE AIR VOLUME FOR THE SUBS.
