Sponsored by: Innova
help passive crossover jumper sr6500
Old Nov 20, 2016 | 05:42 PM
bdanyluk's Avatar
bdanyluk
Default help passive crossover jumper sr6500
Does anyone know where i can buy replacement " jumpers" for my polk sr6500 component passive crossovers?
they are not the tiny ones in a computer...they are the next size up, about 2 times the size of a motherboard jumper.
I cant find these things online anywhere.
Old Nov 23, 2016 | 11:24 AM
WoodyJohnson's Avatar
WoodyJohnson
The technical name for it is a "jumper cap shunt". Probably this one:
http://www.digikey.com/product-detai...1698-ND/769841
Standard is 2.54 mm, this one is 5.08 mm which is twice the size of a motherboard jumper. Do you have one you can measure in mm? Pitch is the distance between pins, I believe.
Old Nov 23, 2016 | 11:36 AM
bdanyluk's Avatar
bdanyluk
Yeah...it's probably the 5.08 size. But disregard...i decided to just keep using my bi-amp setup instead, so i don't need the jumpers now.
I just wired the speakers in parallel to test it out, which is exactly what the jumpers do in the first place, and i didn't like it.
To help passive crossover jumper sr6500
