Help with wiring 2x reverse cams
Reverse cameras are normally powered by the reverse light. You put your car in reverse, the reverse light gets power and then it turns the camera on, and when the receiver detects power from that source it then overrides whatever is on screen and gives priority to that source.
I'm not tying into reverse light so that I can control the power with a switch. So I think I need a DPDT switch with ON-OFF-ON so that I can control the cameras with power. So technically only one camera should be powered at a time.
The issue is that the receiver only takes 1X RCA cable so I need to Y the two cameras together into a single line. Should I need to run diodes in the lines to make sure that camera 1 doesn't shoot power back into camera 2 and then the receiver gets 1 signal that's actually 2 signals combined and then acts wonky?
So my two questions are 1) Do I need a DPDT switch for this?
and 2) Diodes? How do I know what size to get?
I've spent a bit of time searching but can't come up with a clear cut answer to it. Here's a quick diagram I came up with of how I think it should work.
I'll post a drawing of how I'd do the switch (or more likely a relay) later, my plane is boarding
Appreciate the response
Went between the cameras and it works like a charm. No issues with any of it. And I can have a single power source so that's pretty nice.
https://www.youtube.com/watch?v=KaUefQ-0Vx8
