Underbody Lighting
Underbody Lighting
I would like to put underbody lighting on my C6 but want to find out if there is a way to make it a walk up light. My wife's Infinity Q50 has the feature where the courtesy lights, including underbody come on when you are about 10' away. Since the C6 can recognize the fob is near to lock or unlock the door, there has to be a power out somewhere that could turn on the courtesy lights when you get close.
Has anyone attempted this or successfully deployed it?
Thanks in advance.
Thanks in advance.
Hi Jimmy. I had thought about doing that already. The courtesy light circuit is wired that way now. I could just tap into that. What I am wondering is if someone has located the circuit that tells the car a fob is present. That could trigger underbody lights as well.
I rarely get my keys from my pocket since they are not needed to unlock the car. Like I said my wifes infiniti has all the courtesy lights, including the underbody lights, come on about 10' away with the fob. That is what I am hoping to do.
