Sponsored by: Innova
Need speaker info for '89
Old Sep 30, 2002 | 09:44 AM
Gixster's Avatar
Gixster
Default Need speaker info for '89
I'm about to yank the Bose stuff and put in an aftermarket headunit and speakers.
I've already selected the headunit I want to go with, a Kenwood KDC-X659. What I would like to find out is what everyone's experience is with sizes for door speakers and rear speakers that do not require huge amounts of modifications. I know that a little bit of drilling will probably be required, I don't mind that. What I don't feel like messing with is building plates, etc, to make 6-1/2" speakers work in the doors, which is what I'm seeing.
Also, any suggestions on speaker brands that sound good would be appreciated as well. I'm currently leaning towards Infinity. :)
Old Sep 30, 2002 | 01:09 PM
Kale's Avatar
Kale
Default Re: Need speaker info for '89 (Gixster)
tell us how much you want to spend.
and in the doors, I mounted Focal 165w midranges (which are considerably deeper than infiniti speakers) and had to use a dremel to "make room" in the fiberglass for the speaker to fit through, and then a MDF mounting surface.
Old Sep 30, 2002 | 03:49 PM
_Nomad_'s Avatar
_Nomad_
From: Frankenstein never scared me. Marsupials do, because they're fassst…and they DART, THAT'S crazy!
You will not have a problem putting 6x9’s in the rear, all you do is remove the Blose pod and there is a stock plate already there where you can put a 6x9 speaker. If you are not running a sub(s) then 6x9’s will be a better choice for the rear.
The doors are another story. You can easily put a 4” speaker in the stock Blose pod without any cutting, however, you won’t get any sound from that small a speaker set that low.
A 5.25” speaker can be set in the Blose pod with minimal cutting of the pod for diameter fit. In each of the above cases the stock speaker grill cover may be used to cover the aftermarket speakers for a clean, stealthy install.
A 6.5” speaker can be fit into the stock Blose location but will require both cutting of the pod and using a baffle (spacer) to allow for depth. MDF is a good choice of material to build a baffle from.
The dash has locations for 4x6 speakers. They are a good place to put either “plate” speakers or a small 4” mid 1” tweet comp set but will require a little cutting for proper fit. Not a difficult job though.
I would recommend you run amps to the speakers if possible.
Good luck.
Old Sep 30, 2002 | 04:35 PM
Gixster's Avatar
Gixster
Default Re: Need speaker info for '89 (The^Nomad)
Nomad, thanks for the detailed info, that's what I'm looking for !
6x9s sound good for the rear. As for the fronts, I think the 5.25 sounds like what I want. Would a component system for the doors work ? Where would the tweeter be best mounted at ?
On the amp, I assume I can get one amp to run all the speakers ? Any suggestions on where everyone is putting them ?
Suggestions on specs would be nice as well.
Sorry for all the questions, I'm a stereo newb. :)
Old Sep 30, 2002 | 04:52 PM
Kale's Avatar
Kale
I'm using FOCAL 165W components up front, it requires modification/cutting/etc. Send me an email to pic@lostknights.com and I'll send it to you tonight.
try us acoustics amps
3 year warranty from crutchfield.com
Give u a budget
To Need speaker info for '89
