Rockford Fosgate and Eclipse amp
Eclipse and Rockford amps are consider as mid class to high end amps ...
Thanks :cheers:
:cheers:
Us Acuostics should be cleaner than both, and they always make at least rated power. They are inexpensive because they are "new." and us acoustics doesn't "price fix" like the more established brands do.
For example, RF has .05% THD, and USAcoustics has .01% thd.
ouch, looks like the eclipse has a .1% thd... that can't be right, must be a typo.. http://www.speakersound.com/index.ht...alog113_0.html
Nope.. .1% is right... http://www.autosound.co.nz/dynindex....amps/32440.htm
Now if you want a really good amp, look at ARC Audio, ZAPCO... Those are "high end" and enjoy THDs of like... .005% or less.
Even if you dont like US Acoustics, you should look at other amps. The 4 channel arc will run you around $950 or so. Ive seen them as low as $599 from "non authorised resellers"
I've got an ARc2100 ($499 retail, i believe the birthsheet put it at 120x2) on my Utopia component set, and it's unbelievable how clean it is.
What kind of speakers are you pushing? If just JL, Inifniti, POLK, Panasonic, or other speakers that can be bought at chain stores, you probably dont need to worry about finding one with the magic THD number of .01% or less.
[Modified by Kale, 12:30 AM 10/2/2002]
What is THD. Obviously the lower the percentage the better, but what does this measure?
[Modified by R94 LT 1, 10:04 AM 10/2/2002]
Do you actually own, or have you ever owned, a US Acoustic amplifier?
Like a Jensen or Sony watt VS an actual wat... :D
[Modified by Kale, 12:07 PM 10/2/2002]
