Sponsored by: Innova
slight problem, could use some help
Old Oct 6, 2002 | 01:59 AM
MEATHOUSE's Avatar
MEATHOUSE
Default slight problem, could use some help
Ok i was wiring my car today and had to remove the battery to sneak the wires through the firewall hole. I reconnected the battery and my radio says LOC. Looked in the instruction manual and it says put in the code... well i bought this car used and getting in touch with the original owner will be a PIA, it also says contact the dealer. Does anyone know what the dealer is going to do so that i can fix this myself????
thanks, Justin
Old Oct 6, 2002 | 04:39 AM
JoeyG's Avatar
JoeyG
Cruise-In III Veteran
Cruise-In IV Veteran
Default Re: slight problem, could use some help (MEATHOUSE)
Dealer either calls and gets an override code, or there is a rest button on the radio somewhere and tech supports gonna tell them how to do it.
My best guess.
