Sponsored by: Innova
can't receive calls
Old Nov 9, 2017 | 08:28 PM
ROD BROWN's Avatar
ROD BROWN
Default can't receive calls
Hi,guys,I have a 2016 LS1 Vette.I paired my radio to the car using blue tooth.I can call out without any problems,but I can't receive calls.Some times it works if the caller's phone keeps ringing.Usually we are disconnected.I took it to the agency and the tech said the programs in the car are conflicting with the blue tooth.I would think if there was a conflict I couldn't call out Any suggestions?Thanks to all who reply.Rod
Old Nov 10, 2017 | 12:27 AM
jdmvette's Avatar
jdmvette
Night Owl for life
Old Nov 10, 2017 | 11:57 AM
Homer3D's Avatar
Homer3D
I don't know what a 2016 LS1 is since they don't exist, but in any case, when you receive a call how are you picking up the call?
Are you using the pick up button on the radio or on the steering wheel?
I don't have a C7 but it if like the C6, you have to press and hold the pick up button on the steering wheel to actually pick up the call. You can't just quickly press it.
Old Nov 10, 2017 | 08:38 PM
ROD BROWN's Avatar
ROD BROWN
Default Can't receive calls
Sorry,my car is a LT1.I try to connect with the incoming call by using the button on the steering wheel.I will hold down the button longer and see if that takes care of the problem I haven't tried to use the button on the radio,but I will try that also. Thanks again,Rod
Old Nov 10, 2017 | 09:17 PM
ROD BROWN's Avatar
ROD BROWN
Default It works!
Thank you so much! Owners stupidity.I wasn't holding the button on the steering wheel down long enough.My 2009 had blue tooth in it and it worked much faster.
To can't receive calls
