Sponsored by: Innova
replace bose in c6
Old Feb 16, 2018 | 10:33 PM
ocphotojg@gmail.com's Avatar
ocphotojg@gmail.com
1st Gear
Default replace bose in c6
can place bose speakers with better ones?
Old Feb 17, 2018 | 07:18 PM
c6crazy's Avatar
c6crazy
hybrid audio or focal will blow away Bose..if change headunit also you will be surprisingly amazed.
Old Feb 18, 2018 | 11:10 PM
Gutch94's Avatar
Gutch94
I just changed out the OEM NAV unit in my '06 (went with a Kenwood DDX9704), but kept the Bose speakers. Will tell you that, IMO, the improvement in audio quality was incredible and made changing the speakers unnecessary. I listen to basically everything except rap, and there is plenty of volume, more than ample bass, and trebles are crystal clear without being ice pick brittle.
Old Mar 4, 2018 | 08:24 AM
SRQ Vette's Avatar
SRQ Vette
I am planning to do the same thing with a C6 convertible that I haven't bought yet. I will probably use the same Kenwood head unit. Before I make the leap to buy the car, I have a few questions. Anyone with knowledge of the C6 Bose system or who has other helpful ideas is welcome to respond:
1. From what I have read, it seems that the Bose speakers have separate amplifiers attached to them. Is this correct? If so, is there any issue with connecting the head unit to them?
2. Does the Bose NAV system have a separate power amp? If so, should I replace it? I don't need a huge amount of power for the subwoofers that I would install.
3. The Kenwood head has 3 5-volt pre-outs. I assume that would cover the tweeters, mid-woofers in the doors, and subwoofer(s). I am thinking about replacing the rear speakers with good subwoofers of the same size, in the same location. Does this make sense? Would the existing rear speakers function adequately as subwoofers if the crossover in the head unit is adjusted correctly?
4. I am planning to disconnect the center speaker in the dash. Is this the generally accepted recommendation? Is there any reason to keep it connected?
I am not really educated when it comes to car audio systems, but I can tell you that to my ears the existing Bose NAV system in this 2006 Corvette sounds terrible even when the EQ and faders are adjusted as has been recommended in other threads. The stock Infinity system in my 2005 Crossfire sounded much better than the Corvette's and when I replaced the head with a new Kenwood, it became astoundingly great. No new amp or speakers needed. I am hoping that I can achieve similar results in the Corvette.
If I hijacked the OP's thread, I apologize. I hope that he can learn something from your responses to my questions. If necessary, I can start another thread.
To replace bose in c6
