Sponsored by: Innova
Aftermarket stereo boot delay
Old Apr 22, 2018 | 04:42 PM
thedudeman's Avatar
thedudeman
Default Aftermarket stereo boot delay
Installed an aftermarket stereo which works well aside from a boot delay. It can take 30 seconds to several minutes to start after the car starts. I added a ground on the metal mount below the climate control. Has low resistance but curious if that could cause an issue like this. Had same problem on two units now. Are there other grounds I should check or test the wire harness in some way? Stock radio didn't have this problem.
Old Apr 22, 2018 | 05:08 PM
Tsumi's Avatar
Tsumi
Which harness are you using? Is it the Axxess one? If so, I have the same experience with it. I think it is because the harness occasionally has a delay synchronizing with the BCM signal.
Old Apr 22, 2018 | 05:15 PM
thedudeman's Avatar
thedudeman
Yes it's the Axxess one. Just talked to crutchfield and they said there's a software update for a power drain issue on those units. So I'll check that out. I installed a kill switch because the battery kept draining when I had the aftermarket unit hooked up. Anyway, if that doesn't fix it, nothing else to do short of replacing the Bose system?
Old Apr 22, 2018 | 05:18 PM
Moved to Audio/Electronics.
Old Apr 22, 2018 | 05:24 PM
Tsumi's Avatar
Tsumi
Use diodes and hook up the power on wire into an accessory wire. That way it can receive power from the Axxess unit or accessory power, and diodes prevent backfeeding into either system.
Old Apr 22, 2018 | 08:22 PM
thedudeman's Avatar
thedudeman
Have you done it? Any pics? I haven't used diodes before.
Old Apr 22, 2018 | 09:00 PM
Tsumi's Avatar
Tsumi
I have not. I plan to at some point, but just haven't gotten around to it.
Here is a rough schematic of what it would look like:
Old Apr 23, 2018 | 05:45 PM
thedudeman's Avatar
thedudeman
Thanks. I just updated the Axxess interface with their pc program. It was version 2.4, updated to 3.5. It did not fix the delayed boot issue, but I'm leaving the kill switch off tonight to see if it fixed the battery voltage drain issue. It would be nice to at least not have to use the kill switch all the time.
Old Apr 30, 2018 | 10:17 PM
thedudeman's Avatar
thedudeman
Battery still drains when the radio is plugged in. Using kill switch for now.
Old Apr 30, 2018 | 11:12 PM
jrprich's Avatar
jrprich
Tsumi,
What size diodes would you recommend for this?
And which Accessory source would you tap?
Thanks,
Jim
Old Apr 30, 2018 | 11:20 PM
Tsumi's Avatar
Tsumi
The radio power on wire doesn't carry that much current, any diode that can handle at least 2 amps will be enough. Most radio power comes from the yellow wire. I would recommend a 5 amp diode, as those seem to be readily available and gives safety room.
Old Apr 30, 2018 | 11:40 PM
jrprich's Avatar
jrprich
Thanks for the info. I will add this to my harness just in case.
Jim
Old May 2, 2018 | 09:03 PM
madsonp's Avatar
madsonp
If see a number of issues with the Axxess units, I'd suggest you rip it out, throw it away, and install a PAC one instead
Old May 2, 2018 | 09:14 PM
Tsumi's Avatar
Tsumi
The Axxess units are the only ones that allow you to keep RAP, which I rather like.
To Aftermarket stereo boot delay
