89 antenna problem on aftermarket JVC radio
I just installed a JVC radio in my 89.
The problem that I'm having is that as soon as I turn the ignition on, the antenna goes up whether the radio is on or not. Other than this, the unit works perfectly.
I have the pink antenna wire hooked up to the red ignition power wire. Just as it was on the previous radio, an aftermarket Pioneer.
There must be a way for the antenna to operate correctly without the use of a toggle switch.
Any advise would be greatly appreciated.
Bill
Bill
depending on your JVC uhit,, you should have a blue and blue with white wire. Connect the pink wire from your antenna to the blue wire of the radio and not the ignition wire.
Vince is correct, the way to have it wired it is working correctly.. usually radios have a remote wire and a Power antenna wire, this will then give you the correct functionality for the antenna.. remote for amps and Power antenna for the antenna (Obviously). the antenna works only when radio it on.
this will help:
https://www33.jvckenwood.com/pdfs/B5A-2125-00.pdf
Antenna will always be up with this radio, it only has a remote (for amps) not a separate one for the antenna
