Sponsored by: Innova
HU Dash Kit for a 92 coupe?
Old Oct 28, 2002 | 05:13 PM
my ride's Avatar
my ride
Default HU Dash Kit for a 92 coupe?
:confused: I read in this forum that several members have found dash kits to install a 1 DIN HU with an area for CD storage below. The posts that I read never included Metra P/N's. I called Metra and they say they don't sell any kits for a 92 with Bose. Can someone post either a P/N of a Metra kit they used or at the very least a point of contact at Metra. Any help would be appreciated. Thanks!!!
Old Oct 28, 2002 | 09:51 PM
Dokken's Avatar
Dokken
Default Re: HU Dash Kit for a 92 coupe? (my ride)
I don't have the contact name.
Here is the part # that fit underneath the Alpine.
88-00-9000 Metra Multi-purpose pocket
If you have the same trim then it works behind it. There are many parts in the bag. I used the thicker bezel behind the stock trim.
My home job included a "frame" to hold the Alpine to the Metra pocket. I used two side radio brackets in the rear sides.
The front was Home Depot garage door opener holder bracket, bent all around to create a "front frame" screwed to the din pocket front. Take your time and think about it.
The radio and the pocket became an assembly unit. There is nothing to bolt it too but it fits snug. Foam works for the base and to fill in the lower gaps.
I also dremmeled (I don't suggest you do it) * be very cautious there are harnesses around the top of the box if you do it* the black box in dash and it was a biatch but there is good airflow and room to work.
This is provided the 92 is the same as the 90 good luck. :smash: :cheers:
Old Oct 28, 2002 | 11:52 PM
92TripleBlack's Avatar
92TripleBlack
Default Re: HU Dash Kit for a 92 coupe? (Dokken)
But I put my deck on the bottom to make it more stable. Also was able to angle the pocket down more in the rear so gravity would hold more objects under acceleration and I no longer punch the head unit buttons during shifting.
Old Oct 29, 2002 | 09:06 AM
my ride's Avatar
my ride
Thanks for the info Dokken & 92TripleBlack! :)
Old Oct 30, 2002 | 09:01 PM
Dokken's Avatar
Dokken
Since this is fresh in my mind, here are a few other obstacles.
See my "C4 bose head unit and Speaker replacement" thread for my picture of the finished product.
- The 1990 has a 1 & 1/2 din sized opening.
- You will need one or both of the following Antenna adapters;
Metra 40-GM10 mini plug to aftermarket antenna adapter
It was just a bit short so I got a universal Extension cable, 3 ft I think.
- When looking at the removed Bose opening, note the peg hole in the back, guide pin and support for the Bose.
- I cut a horizontal line accross the back of the box from the MIDDLE of the hole.
- This will support the rear of the Alpine as it goes deeper into the cavity.
- I also had to extend the Alpine harness about 3 ft to reach the CDM where the METRA 21 pin interface meets the factory harness plugs that are accessible from the CDM. There you will get, 12 volt fixed, 12v switched, power antenna lead and ground....and what I overlooked, the darn antenna line itself, pull hard to get that biatch out.
- It required alot of soldering, you can use butt connectors but I don't use them since soldering guarentees connectivity.
- Once you cut the rear of the box there is room to drape the cables from the rear of the radio into the crevice behind the black Bose box.
- I have had this done for about 2 weeks and love it. Triple92 had a good idea in angle for the Metra pocket. Under hard acceleration, CD jewel cases will fly out. However, I use only the lower holder with the mini-jewel cases for stacking. The center console still has tons o' room for CD's so mine is more for asthetics and less for holding CD's.
- Final suggestion is to drill holes in the upper part of the pocket for venitilation. I only wish someone else had done this and documented it. It does require patience and alot of time to do it right. If you rush it, you'll may screw it up.
:crazy:
Old Oct 30, 2002 | 11:29 PM
92TripleBlack
You may or may not need to get the antenna cable from the receiver. Some radios have the antenna cable hooked directly up to the receiver which is located under the dash pad on the passenger side. Real hard to get to. Other have the antenna run to the head unit. If you have it run to the receiver, as mine was, my solution was to plug into the antenna where it comes through the body. It has a standard plug there. Its under the carpet at the rear of the driver's side. Just unplug the stock wire and plug in a 12' extension there and run it to the radio. Much easier than trying to access the receiver and all you need to reverse it is switch plugs instead of ripping apart the dash a second time. :cheers:
[Modified by 92TripleBlack, 10:30 PM 10/30/2002]
To HU Dash Kit for a 92 coupe?
