Sponsored by: Innova
Question: JL Stealth Box - is it worth it?
Old Nov 4, 2002 | 09:15 AM
NoleC5's Avatar
NoleC5
Default Question: JL Stealth Box - is it worth it?
I have been thinking about getting the JL stealth box. Does anyone out there have any opinions on this? Currently I have 1 12" JL W3 in a ported box in an Acura CL Type S. Is this stealth box worth the money? Does anyone know where I could get cheaper? Hi Fi Buys here in atlanta wants $500 for it.
Thank you
Old Nov 4, 2002 | 09:21 AM
Conquer's Avatar
Conquer
St. Jude Contributor
Default Re: Question: JL Stealth Box - is it worth it? (NoleC5)
I've heard it and to me it sounds great for a 10". However, I would do a custom box for a little more $$ and stick with the 12".
My $0.02 :)
Old Nov 4, 2002 | 09:28 AM
NoleC5's Avatar
NoleC5
Default Re: Question: JL Stealth Box - is it worth it? (Conquer)
Is it possible to do this and keep it flush with the floor? I'd really like to do the 12" but I want it to still be kind of a stealth install.
Old Nov 4, 2002 | 09:55 AM
M396 #00-011's Avatar
M396 #00-011
Anything is possible. Many have done a sealed 12" that is level with the top. You will yield about 1.25 cuft max air space. If you are used to the 12, go for it, but if you are porting it, it may take some time to tune it right in that small of space.
Old Nov 4, 2002 | 11:32 AM
Conquer's Avatar
Conquer
Yes! :)
Old Nov 4, 2002 | 12:08 PM
mrkln's Avatar
mrkln
I have a 12" IDMAX mounted in 1.25 ft^3 and it is exactly flush with the hatch floor. I would recommend going with a 12" driver as well. I actually have an older 12" round Kicker solobaric that I am wanting to sell. As long as you could put a minimum of 400W on it, I could sell you that and even fab a box for it if you needed. That driver only needs 0.88 ft^3 to work so it would be very easy to fit into the center well. :yesnod:
Old Nov 5, 2002 | 01:04 PM
lotzahp's Avatar
lotzahp
Default Re: Question: JL Stealth Box - is it worth it? (mrkln)
ironic - I just finished my box for my old 12" round Solobaric !
I must say, making the box to fit that center well was not the easiest one I've ever done. It has many irregular shapes (like the side walls taper down).
I don't think the Stealthbox is worth 5 bills personally. $300 is realistic.
To Question: JL Stealth Box - is it worth it?
