Looking for smaller footprint amps
You're getting a lot of power out of those arcs. I'm afraid running the fronts passive on way less power is going to be disappointing
Still trying to figure out where to put new amps.. I think the dual 5 channel amps could work, however I am not in a position for the amps and DSP all in one shot.. Need to look a bit more
This year, I switched the tweeters and 4s along with the passive crossovers. I have a DRT24 and ES-02 in the front using the mx1000 crossover. , I am thinking I could probably ditch the DRT24 and use the ES-02 by itself with the 6.5",
my concern is the 6.5" in door and 2" in the stock location only, however, the tweeter could be left there if I decide to add them back in.
I still have the other tweeters and 4s. I could swap in the 4s if I decide to stay 3-way. I think the ES-02 is a nice sounding speaker and if I am going to a DSP, ditching the DRTs for the ES-02 Wideband tweeters might be a better move.
Going by the above. I could do the PN4.520 and the PN1.650. then add the PN2.350 if needed later
The two PN5.640 would be good too.. offers a lot of flexibility..
however, I would need to install them first, sell the KS300.4 then buy the DSP.. due it a limited budget for car stuff
OR buy the DSP, use my current amps and go to a 2 way in front. Simpler might be better
