I am looking for wiring diagrams for the complete exterior door switch circuit (probably is the whole door switch circuit period) on the c6 Corvettes. I have a custom build going on. I want to shave the door handles, but i don't want to use only door solenoids and poppers. This leaves the passenger at the driver's mercy until the driver pops the door with the key fob. If they go to get something from th car and forget to ask for the keys they'll have to come back. What a pain.
I want the door switches to only function when the car has been set to unlocked from either the key fob or the interior lock switches just like they do from GM. Can someone provide me with the complete wiring diagram that shows every relay and component I need to implement this setup in another vehicle or direct me on where to go to find it? Thank you in advance.
I suggest you post this question in the C6 General Discussion section of this forum, you'll probably have better luck getting an answer there, this page tends to be more for audio electronics.
